Author Topic: BBB Hot tub  (Read 17219 times)
Re: BBB Hot tub
« Reply #75 on: June 30, 2016, 09:41:43 PM »
Did you get the boiler working?
I have two pool pumps, two new cartridge filters, some 1 1/4 pipes and clips and T pieces and will bring some chemical test strips. Also bringing 15 litres of the palm based biodiesel I use for my heating system.
If you are really desperate and cant get any burners working, I could pull the burner from my pool boiler as wont need to heat that for the weekend and bring it up but would prefer not to
Re: BBB Hot tub
« Reply #76 on: June 30, 2016, 09:53:43 PM »
All loaded up bit of food to throw in tomorrow.
On the down side Vijay owes me a pint that transfer pump is choking me with
diesel fumes.
Hopefully embarking Friday noon.
Re: BBB Hot tub
« Reply #77 on: June 30, 2016, 10:00:20 PM »
No but I've got my old electro oil burner running of a fashion, well once its fired up it seems fine and it fits ok ish in the boiler, I had a quick look and think we should be able to rig the thermostat as it looks like it just cuts the mains power, so fingers crossed, but it's good we have the M67 on standby.
Re: BBB Hot tub
« Reply #78 on: June 30, 2016, 10:24:06 PM »
The thermostat does just cut the power to the burner on most of them so easy to rig up
Re: BBB Hot tub
« Reply #79 on: July 01, 2016, 12:36:05 AM »
How many times have you been there, you should know the way.
We'll give you the post code to your house just before you leave the field, we don't want you getting lost do we.
after falling on my head, I repeatedly forgot my way home  ???
Re: BBB Hot tub
« Reply #80 on: July 01, 2016, 01:34:42 PM »
We are on route. M67 and drum *just* fitted in the Passat with some heavy tail gate slamming. Hope I don't need to get at the spare tyre  ;D
