Author Topic: Solid glyc disposal  (Read 5683 times)
Re: Solid glyc disposal
« Reply #15 on: April 12, 2016, 04:27:41 PM »
Possession is 9/10th of the law!
« Reply #16 on: April 12, 2016, 07:39:11 PM »
Skip went today, I've not heard anything but maybe they've not emptied it yet!  I did say what I would be putting in it when they quoted though.
As far as I'm aware they empty the load straight away, there's no money in full skips sitting around.
« Reply #17 on: April 12, 2016, 09:38:39 PM »
It depends where they tipped it, if it's gone straight to landfill you'll most likely be ok, but if it's been tipped in a transfer station it can take a couple of days for anything to filter back to you.
Almost forgot the other option, it may have been tipped in an energy from waste facility (burner), at which being combustible there should be no problems.
« Last Edit: April 12, 2016, 09:41:36 PM by Head Womble »
« Reply #18 on: April 12, 2016, 10:04:55 PM »
It was mixed though, lots of steel at the top, wood and some electricals, then glyc at the bottom.  I imagine they would reclaim any steel.
« Reply #19 on: April 12, 2016, 10:08:26 PM »
It's a good bet that the driver will harvest the metal before the rest is tipped.
« Reply #20 on: April 12, 2016, 11:39:31 PM »
Bizarrely they've just e-mailed me my order confirmation again (at 9:30pm?).
Edit: It's a collection receipt, it turn out.
It lists code 20 03 01 (mixed municipal waste).
Quote
mixed municipal waste’ arising from a light industrial unit
should have an accompanying written description which might read:
‘General non-hazardous waste from light engineering
consisting only of waste food from the canteen, paper, metal,
cardboard & plastic packaging and floor sweepings’
« Last Edit: April 12, 2016, 11:42:36 PM by Tony »
« Reply #21 on: April 12, 2016, 11:52:16 PM »
So if I cut the cubies open and drop the solid glyc on to the floor then shovel it up I'm ok?
Offline Bill
« Reply #22 on: April 13, 2016, 07:52:36 AM »
If you want something to shovel it into you could use a cubie with the top cut off!
Both sold
