Author Topic: Latest batch....  (Read 2754 times)
Offline Bio-boy
Latest batch....
« on: February 02, 2016, 11:29:44 PM »
Decided to cold wash my latest batch. Having obtained a complete 10/90 pass via a 2 stage reaction i opted to cold wash; 1 to save money and 2 to to try something different. I noticed that cold washing appeared to cause greater soap to settle after each wash cycle. I washed the batch 5 times which is the same as my usual hot wash process yet by cold washing I appeared to be removing more soap. Water was then crystal clear so I then dried my batch using the same process as usual and sent a sample away for testing.
Results for soap content came back non-detectable i.e. less than 10ppm.  :D
It may have been beginners luck but I'm liking the results.
I will continue to cold wash for my next few batches to confirm if cold washing really is the way forward.
Re: Latest batch....
« Reply #1 on: February 03, 2016, 12:46:13 AM »
Does it take a lot longer for the wash water to settle out?
Offline Bio-boy
« Reply #2 on: February 03, 2016, 07:41:05 AM »
In my experience thus far, no. It was my first attempt at it but I'm very happy with the results.
dgs tested my sample and the soap was non-detectable which I'm informed means <10ppm.
« Reply #3 on: February 03, 2016, 06:55:27 PM »
Interesting post Rob. I wouldn't have believed cold washing would be so efficient.
« Reply #4 on: February 03, 2016, 09:26:42 PM »
When I used to wash it was always cold, I didn't think anyone used warm water, certainly not when I was washing, HCII first told me to do it cold when I asked about washing for the first time and I always had good results.
Offline Bio-boy
« Reply #5 on: February 03, 2016, 09:35:40 PM »
Chug I don't mean using warm water....I mean using cold water straight from my mains supply and washing when the bio is also cold/ambient temperature. Initially I was looking to see if I could reduce processing costs/time by now having to heat the bio prior to washing.
Initial results look promising but further testing will be necessary just incase it was a fluke this time around.
« Reply #6 on: February 04, 2016, 12:12:11 AM »
yes I know, that is what I was saying too
I always washed cold bio with cold water, its not a fluke it works perfectly
Using warm water and/or warm bio seems all wrong to me, if people do this then things have gone backwards it seems.
« Last Edit: February 04, 2016, 12:16:11 AM by Chug »
Offline biobill
« Reply #7 on: February 04, 2016, 01:21:15 AM »
 I have always used hot water in my hot bio and had no problems what so ever and I use a 5 inch twin blade paddle running at 2850rpm now that's what you call washing bio lol
Offline Bio-boy
« Reply #8 on: February 04, 2016, 08:17:59 AM »
What sort of soap content are you left with on completion of your washing process?
