Author Topic: First test with the filtered WVO on the diesel bike  (Read 11400 times)
Re: First test with the filtered WVO on the diesel bike
« Reply #15 on: December 10, 2015, 07:27:15 AM »
An addition to the possible things to check: Compression.
White smoke is an indication of retarded timing - which can be caused by low compression, air in the fuel, or the actual timing of the injection pump.
Looking at the video though - it's not that smokey. My money is still on timing.
« Last Edit: December 10, 2015, 07:31:27 AM by therecklessengineer »
Offline alexanderfoti
« Reply #16 on: December 10, 2015, 07:10:14 PM »
That is truly a beautiful sound.  I'm surprised it sounds so good running on cold veg to be honest.
Thank you, I love it too :)
« Reply #17 on: December 10, 2015, 07:10:55 PM »
I have been told to check compression too, however the previous owner had the head off and everything looked ok on the bores etc, so I would be surprised if its down on one cylinder.
« Reply #18 on: December 20, 2015, 07:16:58 PM »
Update :
Compression good, 400psi across 3 pots when cold.
Cleaned the injectors and advanced timing by 4.5 degrees. Bike runs sweet now:
https://youtu.be/3YfFYmIbDxI
« Reply #19 on: December 22, 2015, 11:52:29 AM »
You do know I watch your videos just to listen to that soothing engine sound? :)
Glad to hear it is running well!
« Reply #20 on: December 22, 2015, 12:24:58 PM »
It is rather addictive. If you look throigh my YouTube channel, there is a plethora of different engine videos :)
« Reply #21 on: December 22, 2015, 09:12:26 PM »
glad to hear you got it sorted, sounds nice now, I like the sound of this one too
https://www.youtube.com/watch?v=NkbEwQAe3aQ
