Author Topic: Trouble with pdfs again!  (Read 9062 times)
Re: Trouble with pdfs again!
« Reply #15 on: September 29, 2012, 09:43:46 PM »
Yes, it is a Jpeg. Connection speed is slow, so may be something to do with it, Always goes on a downer the minute need it fast.
« Reply #16 on: September 30, 2012, 09:37:46 AM »
I've had the same a few times.  I think it might time out if the file is large.
If it proves too difficult, try resizing the file.  800 pixels wide should be OK for a wiki page.
« Reply #17 on: September 30, 2012, 10:39:32 AM »
It might be a timeout problem, however I don't know if that is the server or router or what.  It does suggest there is a problem of some sort my end.  Maybe the webserver (lighttpd)?
« Reply #18 on: October 16, 2012, 09:12:37 PM »
I've tried up loading a picture onto the special page on the wiki a few dozen times over the last couple of weeks, and It's not having it. It is a Jpeg.
Anyone got any ideas?
« Reply #19 on: October 16, 2012, 10:17:47 PM »
What error do you get?  There was a problem that crept in with a software update which I fixed I think last week.  But if you are seeing an error let me know.
Is the photo particularly big?
I'm fiddling with the wiki stylesheets at the moment so hopefully won't break anything else!
« Reply #20 on: October 16, 2012, 10:23:33 PM »
I don't get an error. It appears to upload, there is a percentage thing going in the bottom left hans of the screen. It reaches 100%, then the screen just stays the same. I go to look in uploaded files, and its not there. It has occurred to me that I may be looking in the wrong place.....
I'm sure the photo isn't to big, but I'll check anyway.
Of course I could be wrong........
I've just taken a look, and it says the photo is 2.57MB. The page says max size 2MB.
Does that mean that it won't load?
How do i make it smaller?
« Last Edit: October 16, 2012, 10:26:57 PM by greasemonkey »
« Reply #21 on: October 16, 2012, 11:05:06 PM »
That'll be it - one solution if you don't have an image editor is:
http://www.picresize.com/
Otherwise I can recommend http://www.getpaint.net/ as a useful editor.
« Reply #22 on: October 16, 2012, 11:25:52 PM »
Captain Caveman strikes again!
I could just set the picture quality on the camera lower and retake the picture. Failing that I'll try and resize it. Thanks for the links. That getpaint one looks real handy. i might try downloading that. I've wanted a good photo editor for a while.
Cheers.
« Reply #23 on: October 17, 2012, 09:12:05 PM »
I use MS paint,just open the pic with it,then save as,job done
« Reply #24 on: October 21, 2012, 09:29:18 PM »
Well I managed to upload the picture. It was failing because it was to big, so I reduced it using Paintbrush. Nearly finished the page now. Thanks all.
« Reply #25 on: October 21, 2012, 11:29:08 PM »
Nice one  8)
