Author Topic: Sourcing a connector  (Read 5285 times)
Re: Sourcing a connector
« Reply #15 on: September 16, 2015, 04:58:12 PM »
I'm sure you're all bursting with curiosity to find out if the plug fitted (Yeah, right ... but I'll tell you anyway)
Fits a treat, wire size is right but the bally colours are round the wrong way!
I could probably get round it with judicious use of shrink wrap however, has anybody tried dying/painting pvc wire?  What about upholstery paint you used to get for vinyl car seats?
If I could make them both black that would do.
« Reply #16 on: September 16, 2015, 06:46:04 PM »
the seller might have them with the colours the other way around ?
the male of one connector plugs into the female of the other connector.... so you'd need different wire colours for each pair of connectors otherwise the wire colours would swap ?
« Reply #17 on: September 16, 2015, 06:56:30 PM »
They must be handed. A matching pair will have male and female opposite colours to its butty.
« Reply #18 on: September 16, 2015, 07:33:12 PM »
I know I may look pretty daft, but I've already asked the question ... he only sells that orientation to match up with Motorola equipment.
« Reply #19 on: September 16, 2015, 10:03:23 PM »
Oh, bit of snag, then. Looks like your into coloured insulation tape.
« Reply #20 on: September 17, 2015, 03:27:16 PM »
What you want is some one with a 3d printer.......... :P
« Reply #21 on: September 18, 2015, 02:33:59 AM »
you can buy reels of heat shrink....  you could cut it to the right length and do a bunch all at once ?
hot air gun / paint stripper thingie work great for heating/shrinking it
« Reply #22 on: September 18, 2015, 09:32:00 AM »
Maybe it would be easier to change the existing connector to something else like standard bullets?
« Reply #23 on: September 18, 2015, 11:03:06 AM »
If I can only buy connectors in this orientation, then using two the same will still result in the colours being mismatched!
The idea would be to supply a battery c/w connector for people to fit to an existing machine, so I've no control over the other connector.
« Reply #24 on: September 18, 2015, 02:53:00 PM »
I meant just snip off the connectors you have and replace with standard bullet connectors.
« Reply #25 on: September 18, 2015, 05:27:29 PM »
Ah, sorry, got you!
Good suggestion but not possible for logistic reasons I'm afraid!
