Author Topic: Centrifuging Biodiesel  (Read 19689 times)
Offline Bio-boy
Re: Centrifuging Biodiesel
« Reply #60 on: December 15, 2015, 04:24:02 PM »
Dave, the OB-050 wall mountable kit is supplied with the 230/3 pump.
I appreciate that there may not be much to be gained from a fuge in terms of glycerol/soap following the production of good quality water washed bio but I'm chasing the best fuel I can possibly make. I filter to 5 microns and a fuge is capable of sub 1 micron without the expense of replacement filters. The benefit being that should there be any residual glycerol/soap it will reduce these slightly too which is an added bonus.
Offline Bio-boy
« Reply #61 on: December 15, 2015, 04:25:29 PM »
Dave at what temps are you centrifuging your bio?
« Reply #62 on: December 15, 2015, 04:59:20 PM »
I do it at ambient. As it is much thinner than WVO there is no need to use heat. The centrifuge does however heat it up a few degrees. Pleased your pump will be the right one.
