Author Topic: My New Plant...  (Read 10288 times)
Offline Bio-boy
Re: My New Plant...
« Reply #15 on: August 08, 2015, 09:36:52 AM »
so am i not getting my mushroom cloud then? :-\
Hopefully not.  ;)
Offline Bio-boy
Re: My New Plant...
« Reply #16 on: August 08, 2015, 09:47:38 AM »
Tidy build.  I have mixed feelings on the plastic, but you are experienced and it's your choice of risk.
Quote
Heating element automatically cuts with level sensor.
Big thumbs up for this!
Is there also a secondary over-temperature cut out?  You can buy little thermal fuses that go open circuit over a specific temperature, if you don't already have these it would be worth purchasing some, they're dead cheap.
Looks great though :)  Try and keep it clean!
Thanks Tony. People are all to soon to jump and judge. Health & Safety is paramount to me and if i felt it wasn't safe then I wouldn't be willing to use it. I designed and built it from the ground up. I known the processor inside out and I'm confident in my fitting ability to have done a professional job.
The processor produces A1 fuel too which is also fantastic.
The biggest risk is leaving the heating element on when dry rather than overheating the oil in the plastic tank. Depending on the location and environment the vapours could also cause a concern but not in my case.
Re: My New Plant...
« Reply #17 on: August 08, 2015, 10:32:10 AM »
Hopefully not.  ;)
if you get stuck, let me know
Re: My New Plant...
« Reply #18 on: August 08, 2015, 11:00:59 AM »
Just a thought, if methanol vapour is heavier than air, what is the rooftop ventilation for?
Wouldn't you be better with low level ventilation?
Re: My New Plant...
« Reply #19 on: August 08, 2015, 11:46:43 AM »
There's thems that knows and thems that disn't know.
Re: My New Plant...
« Reply #20 on: August 08, 2015, 03:10:10 PM »
The vapour will get carried out by hot air, as I very well know from my own reactor.
As for a plastic reactor, as long as the op is aware of the risks and decides to carry on I don't see an issue with it. I "sometimes" do things against good advice, when it does go wrong I only have my self to blame!
Haha
Re: My New Plant...
« Reply #21 on: August 08, 2015, 04:04:07 PM »
Really Arash? You don't seem the type ;)
Offline Bio-boy
Re: My New Plant...
« Reply #22 on: August 08, 2015, 04:25:32 PM »
Re: My New Plant...
« Reply #23 on: August 08, 2015, 04:55:42 PM »
Blimey Keef you must be the only one that doesn't know Arash is a mobile disaster looking for somewhere to happen.
Re: My New Plant...
« Reply #24 on: August 08, 2015, 11:25:20 PM »
 ..... so now he's building his own venue!
« Last Edit: August 09, 2015, 12:32:35 AM by Keef »
Re: My New Plant...
« Reply #25 on: August 18, 2015, 02:18:28 PM »
Doesn't it depend on the temperature of the vapour as to whether it rises or falls?
