Author Topic: Bio Sample Tested & Results......  (Read 8195 times)
Offline Bio-boy
« on: August 07, 2015, 06:15:40 PM »
Firstly I would like to thank Dave for his support and taking the time to test a sample from my most recent batch.
Needless to say I am more than happy with the results of the testing. The exact test equipment can be confirmed by Dave as I am not 100% sure on the equipment used. However, I can confirm than a Sandy Brae was used to complete the water testing.
Not wishing to delay proceedings the results are as follows:
Soap content:- 10ppm
Water content:- 225ppm
Both of which far exceed the requirements of EN14214. The only thing I could do with testing is for any residual glycerol/methanol.
However, I am extremely chuffed with todays findings.
Once again thanks Dave.
« Last Edit: August 07, 2015, 06:18:29 PM by Bio-boy »
Re: Bio Sample Tested & Results......
« Reply #1 on: August 07, 2015, 07:11:47 PM »
Just a confirmation of Bio Boy's results as posted above.
As I said to him in my PM, other than samples sent by DavidS and my own (we both use turbo dryers) this sample from BB is the lowest I have ever tested. In fact the result worried me so I immediately tested one of my own samples which was from a batch that is being settled.(not yet dried so expected water level 6 to 700ppm) The result was 600ppm, so I'm pretty sure the Sandy Brae is working accurately.
Soap test was by the usual titration with 0.01N HCL
As I mentioned to BB it would be nice to test one of his samples before passing it through the filter that is supposed to absorb water ( I assume you used this BB) just to see what this filter was doing.
But anyway a really good result. Well done Rob.
« Last Edit: August 07, 2015, 07:15:48 PM by dgs »
Offline Bio-boy
« Reply #2 on: August 07, 2015, 07:24:40 PM »
Dave, this sample was completed using 2x spray bars plus an additional feed used when carrying out the processing. I have yet to install a Coalescer but that was going to be my next addition to my plant. However, I'm now debating following these results if the additional outlay would be either needed or necessary.
« Reply #3 on: August 07, 2015, 07:29:56 PM »
Judging by your above results I wouldn't bother.
« Reply #4 on: August 07, 2015, 07:52:22 PM »
Nice results.
« Reply #5 on: August 07, 2015, 08:02:16 PM »
Since playing with the humidity sensors, I've been wondering just what effect moisture absorption from the atmosphere has on bio samples.
Offline Bio-boy
« Reply #6 on: August 07, 2015, 08:14:25 PM »
Nice results.
It is when you have 575L of the stuff! ;)
Offline Bio-boy
« Reply #7 on: August 07, 2015, 08:24:58 PM »
This is where the magic happens.
Purpose built shed with roof top ventilation.
Offline Bio-boy
« Reply #8 on: August 07, 2015, 08:35:34 PM »
2 12"x1"spray bars plus an additional 1.5" feed into my reactor at 55 deg for 2 hours all assisted via an extraction fan and ducting.
I run the pump for hour prior to adding the extraction to remove any potential methanol vapours. I appreciate that my processor will not be to everyone tastes but hey ho, such is life. I'm more than happy with the results.
« Reply #9 on: August 07, 2015, 08:54:42 PM »
I'm not exactly sure what you mean Julian.
« Reply #10 on: August 08, 2015, 01:32:01 AM »
i collect it, take the chips out and put it in....... :-\
« Reply #11 on: August 08, 2015, 09:20:38 AM »
If you leave a very dry a sample open to the atmosphere, I strongly suspect that it will absorb ambient moisture.
Offline Bio-boy
« Reply #12 on: August 08, 2015, 09:33:16 AM »
I have read somewhere that Biodiesel is in fact hydroscopic and therefore will absorb ambient moisture if left exposed to the atmosphere.
« Reply #13 on: August 08, 2015, 12:26:20 PM »
With you now julian, I was thinking deeper into it. Something like I thought you were suggesting the absorbed water was somehow chemically changing the bio.
Bio Boy, yes it absorbs a lot of water if left open to the atmosphere. In my semi open top storage I found it was absorbing anything up to 100ppm/ week. Which is why I don't leave it in there anymore.
« Reply #14 on: August 08, 2015, 02:03:16 PM »
No, not deep ... I don't do deep!
I guess the rate depends on ambient humidity and the relative dryness of the bio.  Very dry bio might initially absorb atmospheric moisture at quite a fast rate, possibly a logarithmic curve.
I was wondering if this will have an effect on any tests done with humidity sensors.
