Author Topic: BBB photos and chatter  (Read 17169 times)
Re: BBB photos and chatter
« Reply #30 on: July 03, 2015, 11:34:06 AM »
I remoted into my home computer and set 2 printing
but... it's the first thing I've set printing since I formatted so they might not print right... won;t now till I get home and it'll be too late to print more by then....
so if anyone else can print one... go for it :-)
Impressive, I'm struggling to get  mine to work and it's only 2 feet away .. thanks.
« Reply #31 on: July 03, 2015, 12:57:16 PM »
Ok, panic over I've turned a wooden plug.  Not very elegant but it works!
« Reply #32 on: July 04, 2015, 01:00:21 AM »
More lightening than I've ever seen before, over here in high Wycombe.
I'm hoping that you happy campers get through it all OK.
« Reply #33 on: July 04, 2015, 01:39:49 AM »
Many are still partying and avoiding going back to wet tents.
The lighting is impressive!
« Reply #34 on: July 04, 2015, 01:45:09 AM »
Jim brought his printer, sounds like a Saturday project to me.
« Reply #35 on: July 04, 2015, 02:11:35 AM »
Air system is working.
Blower runs (probably with enough force to over come 30" WG ... find out tomorrow) and shifts quite a lot of air through a meter long sparge pipe.
If any thing needs printing now it's ear defenders ... the blower is a tad noisy!
« Reply #36 on: July 05, 2015, 05:02:33 PM »
Here's my photos.
Let the entertainment begin
Please not we followed all the warnings
these were then added to the bottom of the drum
another drum was then added and filled with water
the countdown begins
3....2...1
the end result of of this game was a nice dome in the base of the drum
We want to blow the bloody doors off
« Reply #37 on: July 05, 2015, 08:35:38 PM »
Bleedin' 'Ell, is that an airbag explosive? Do people know they are driving around with these things in their cars........?
« Reply #38 on: July 05, 2015, 08:54:26 PM »
It's OK, it was quite safe.  Womble, for example, used his extensive Health and Safety training only to be discovered shielding himself behind a Jerry Can of flammable liquid.
« Reply #39 on: July 05, 2015, 09:29:20 PM »
Yes it's airbags, that sequence of photos is not quite right, the one of the drum flying in the air was from a single air bag, I was to slow to catch the twin shot one (but it gives a good idea of what was happening and I'm sure someone will post the right one soon).
Julian, you make it sound reckless, we were all stood at a safe distance, honest.
Offline Rossey
« Reply #40 on: July 05, 2015, 09:42:28 PM »
Is Pete asking how he can mount these to the front of his motor?
« Reply #41 on: July 05, 2015, 11:25:26 PM »
Some from the camera:
Chug and Pete with the escapee in the field.
The escapee on the run again
Laying out the base for the pool
Vince and Lynda on assembly duty
Lynda couldn't resist trying the pool, even though there was just an inch at the bottom!  Chunder turns up now the assembly work is complete, of course ;)
M67 heater + heat exchanger coil for the pool (10m of 12mm).  In practise with a 12lpm pump the discharge to the pool was 20C below the temp of the M67 water, so we ran it at 80C with 60C discharge and at peak output got a good 3 degrees an hour rise in pool water temp.
Chickens. Obviously.
The camp fire
The pool getting up to temperature
Vince's patio heater burner, customised for BBB 2015 - it kicked out a lot of heat
The reprobates enjoying the warmth
Chug's little candle-wax powered boat puttering across the pool water
Pete mixing various combination of diesel, veg and engine oil to see what burns
Chilli for dinner!
Keef, jamesrl, oakwoodtv and Arash mulling uses for various parts brought for trade and sale
Around the campfire
The burner in the dark
The start of airbag-drum-doming testing.  Redsailer part fills the drum with water for the first test.
Arash mans the charge ignition circuit
The result of the doming attempts - not a bad job!
knighty and william crosby admire flo's melons
knighty gets a surprise from the womble, donning his newfound airbag mask
« Last Edit: July 07, 2015, 08:26:12 AM by Tony »
« Reply #42 on: July 05, 2015, 11:37:06 PM »
Video of the third detonation: https://www.youtube.com/watch?v=SWZfwrR7dcA
« Reply #43 on: July 05, 2015, 11:44:47 PM »
Some from the phone:
« Last Edit: July 06, 2015, 12:07:19 AM by Tony »
« Reply #44 on: July 05, 2015, 11:56:02 PM »
More from the camera:
« Last Edit: July 06, 2015, 12:07:36 AM by Tony »
