Author Topic: Advise required please....  (Read 12577 times)
Re: Advise required please....
« Reply #30 on: April 26, 2015, 07:42:33 PM »
Any chance of a wiki page on that, James?  It would sit well with the Pump buyers guide page.
We've had people with large processors that didn't work efficiently only to find, after some detective work, they were using 15mm pipework.
I'm happy to redraw and alter any diagrams or graphs you may need.
Could do...if I get time.
Seeing as I wasn't busy enough I thought I'd take on two full time courses at the same time. I foresee a bit of a meltdown soon. Much like that reaction vessel actually!
« Reply #31 on: April 26, 2015, 09:26:38 PM »
I'm not ashamed to say that I prefer Plastic to metal anyday. Over the years I have been careful with them and have never had a problem.
I don't de-meth as using a total of 13% methanol, I don't see the point.
With the TAM 120 I have checked the flow when filling the processor with oil at 11degs C and it is down to 34lpm. However the delivery pressure is massive.
After the methoxide is added, because methanol is not miscible with vegetable oil the resultant mix is opaque in nature. This effect will clear when the mix is about 75% converted. This to me is a good indication of the pump/processor efficiency.
In the past when I have used a weak pump this opaque nature of the mix can last 20 to 30 mins, resulting in KOH amounts of up to around 12gms/litre even on good oil.
With my present set-up even at ambient the opaque mix will clear within 5 mins and doing a 10/90 at this point in the process shows around the 85% conversion level. This is really the result of using a tam 120 with a 1/2" eductor.
The disadvantage of bio boy's very large processor as well as the pump he would use is that to heat the oil in a reasonable time he would need 2 if not 3x 3KW immersions.
It all can get too big to be practical very easily when doing things at home.
« Reply #32 on: April 26, 2015, 09:33:32 PM »
Offline Bio-boy
« Reply #33 on: April 27, 2015, 08:23:00 AM »
I have done my research and plan to run 2 36" 3KW Immersion heaters, 1.5" pipework with the flow taken car of by this pump:
http://www.oilybits.com/pumps-for-liquids-/pedrollo-pro-nga-open-impeller-316-stainless-steel-centrifugal-pump.html
« Reply #34 on: April 27, 2015, 09:41:36 AM »
What you really need is a bio fired boiler. 24kW heats up oil pretty damned quick!
Funnily enough...I have one that needs a new home.  ;)
