Author Topic: Closed impeller / open impeller  (Read 4179 times)
« on: March 26, 2015, 01:26:46 PM »
My interest has been sparked from the comments on simonallen's thread -
My first pumps were those Leo ones (the tam look-a-likes that were cheap on ebay that time).
They were open impeller.  Only once did i ever have to unblock one, and that was my own fault (sucking in lumpy methoxide)
My second pumps were multistage grundfoss ones.  They were good pumps (even the paint was bio-proof, and no capacitor housing issues!) however, they were closed impeller, and would get blocked by bits that would go through my pre-filtering without bother.  And then they were a pain to clean out.
My third pumps, when i get around to it, are the 110lpm jgs600 ones.  I need to check if theyre open or closed impeller (anyone know for sure?) but, from my previous experience, im hoping open...
Anyone else have comments?  From my experience, it would seem that open impeller is the way to go for biodiesel processors every time.
Re: Closed impeller / open impeller
« Reply #1 on: March 26, 2015, 01:50:05 PM »
I don't think you can get quite so much thrust from an open impeller, I think the high pressure multistagers (which I love) are all closed impeller.  But they (Calpeda MXHM203 - I've got four of these) are also designed to be easily dismantled for cleaning if necessary.  It is bit of an extra burden but I wouldn't swap them for anything else.
« Reply #2 on: March 26, 2015, 02:28:42 PM »
The jgs 110 pumps have closed impellers.
The leos have periferal turbine impellers and work on a diferent principle.
« Reply #3 on: March 26, 2015, 03:38:09 PM »
What is meant by open and closed impellors?
« Reply #4 on: March 26, 2015, 03:49:28 PM »
An open impeller has only one disc with spiral blades facing the inlet, like a turbo.
Closed has two discs with the blades between an a hole at the centre of the disc facing the inlet.
« Reply #5 on: March 26, 2015, 04:27:50 PM »
So my Lowara would be closed impellor. Thanks for that Pops.
« Reply #6 on: March 26, 2015, 07:10:25 PM »
JGS110s are closed impeller
My Calpeda CM22E is open impeller and still moves 110lpm. I know it is open impeller as I took it apart and had a look. The spec for them states that they will pump fluids with solids up to 4mm and performance on my plant is as good as the JGS110 one I borrowed from NigelB
Here is a link to them https://www.colglo.co.uk/product.php?product=CALPCM22E
I hasten to add I did not pay £261+vat for mine - I got it for £35 brand new from eBay thanks to the pumpophiles thread.
« Reply #7 on: March 26, 2015, 08:35:38 PM »
It was the pumpophiles that put me onto my Lowara...bless them for they know what good they do for the community.
« Reply #8 on: March 26, 2015, 08:44:05 PM »
"bless them"?
... you don't know how hard life is as a pumpophile.
I've just had to buy my fourth Mono!
« Reply #9 on: March 26, 2015, 08:54:13 PM »
"bless them"?
You mean 3d printing is NOT the Antidote?
Have you thought about breeding the little darlings?
