Author Topic: Poor winter fuel economy  (Read 14663 times)
Re: Poor winter fuel economy
« Reply #15 on: December 16, 2014, 07:12:10 PM »
I know a little about their bioboost product. I took delivery of some a few years ago and contains 2-EHN at about 30%. Can contain up to 70% methanol.FFS
This product was sold to me in a leaking container. Complained about that and they then sent me another....which also leaked. Some people never learn. Ah well!
« Reply #16 on: December 16, 2014, 09:05:20 PM »
Interesting.  What ratio are you dosing?  1:1000 or slightly stronger?
I'm using 1.6:1000 or 40ml/25ltr.
I used to dose 1.5:1000 but 2 x 20ml syringes is a lot easier (it's me "I don't give a shite" pills wot do it).
« Reply #17 on: December 17, 2014, 08:20:00 AM »
I've added 35ml to the estimated 35l in the tank, if that's OK I'll dose the next 25l with 35ml too at Jim's ratio of 1.5:1000.
What is the effect of overdoing it?  Knocking?  I'm bringing 25l of bio with me to dilute the tank with just in case, though at 1:1000 I gather I'm unlikely to see any issues.  I think if anything my fuel pump is slightly retarded.
« Last Edit: December 17, 2014, 08:23:19 AM by Tony »
« Reply #18 on: December 17, 2014, 11:44:35 AM »
Over dosing can cause a serious leak in the bank balance akin to pouring money down the drain.
It can take a while to find the right dose for your vehicle, increase the dose by 0.1ml/ltr until the increase in benifit stops or reverses then go back to the best result.
« Last Edit: December 17, 2014, 11:46:15 AM by Jamesrl »
« Reply #19 on: December 17, 2014, 02:08:40 PM »
My recollection of these types of additives is that dosing levels reach a plateau where increasing beyond it either does nothing or can reduce effectiveness. So as Jim say's a waste of money.
« Reply #20 on: December 17, 2014, 02:50:59 PM »
In all fairness though overdosing by an extra 0.5:1000 is what, 25ml per 50l tank or 32p per tank... some people are paying that per litre of oil.
« Reply #21 on: December 17, 2014, 04:07:22 PM »
True but you wouldn't give me 32p every time you fill your tank would you, you don't mind giving it to your supplier though.
« Reply #22 on: December 17, 2014, 06:42:01 PM »
I dare say you're right Steve. It's a long winded but essential process to find out what the optimum is. At the moment I'm at 3ml but start a reduction program on my next fill up.
« Reply #23 on: December 19, 2014, 02:19:01 PM »
I tell you what, this 2-EHN is good stuff.  Even at the low dose the engine is a lot smoother following cold starting, and I'm not pushing the throttle anywhere near as far to keep it rolling at 30mph.  It's a bit early to know what the effect on fuel efficiency is but I'm pretty hopeful about this!
« Reply #24 on: December 19, 2014, 05:05:32 PM »
Interesting. Got to be good if it needs less throttle.
« Reply #25 on: December 19, 2014, 07:00:32 PM »
Welcome to our world                                 eventually.
« Reply #26 on: December 19, 2014, 08:37:35 PM »
He'll be water washing next ;D
« Reply #27 on: December 19, 2014, 09:16:38 PM »
He may be a bit slow but he ain't that daft y'know.
« Reply #28 on: December 19, 2014, 09:30:00 PM »
Aye..I dare say you're right.
« Reply #29 on: December 19, 2014, 09:34:15 PM »
I'm not very often wrong but I'm right again.
