Author Topic: What Capacitor? TAM 120  (Read 11450 times)
Re: What Capacitor? TAM 120
« Reply #15 on: November 15, 2014, 06:45:55 PM »
From what I remember of my capacitor melt down on the lowara you can fit one with a higher uF rating but not one with a lower value.
Offline hifly
    • waste oil devizes
« Reply #16 on: November 16, 2014, 12:45:43 PM »
sorry to be late with the info, i put it down to dead brain cells, not sure how that happened  8)
anyway my tam 120 has a 40uF 450v ac Cap.
Vince
VW T4 2.5Tdi
« Reply #17 on: November 16, 2014, 01:32:25 PM »
Vince
Cheers Vince :)
Offline hifly
    • waste oil devizes
« Reply #19 on: November 16, 2014, 07:12:18 PM »
Yes, that is exactly the same as the one in my tam120, same size 92mm and same connections, just make sure you plug it in the right way round.
VW T4 2.5Tdi
Offline hifly
    • waste oil devizes
« Reply #20 on: November 16, 2014, 07:17:16 PM »
slight correction mine has no bolt on the end you may have to cut that off
VW T4 2.5Tdi
« Reply #21 on: November 16, 2014, 07:18:54 PM »
Thanks again Vince
« Reply #22 on: November 16, 2014, 08:34:51 PM »
Just make sure you plug it in the right way round.
Motor capacitors are not polarized can be connected ether way round.
« Reply #23 on: November 16, 2014, 08:40:59 PM »
When i get it i may have to check on here, when it blew it blew the spade terminals off, so it might not be clear
Offline hifly
    • waste oil devizes
« Reply #24 on: November 16, 2014, 09:06:12 PM »
Ok , did not know that
VW T4 2.5Tdi
« Reply #25 on: November 21, 2014, 06:05:56 PM »
Well the new capacitor hasnt cured it, how do i test the windings just to be sure its dead?
Looks like i will have to fork out a couple of hundred :(
« Reply #26 on: November 21, 2014, 06:09:03 PM »
Even though it's new, it might be worth testing the capacitor too ... but it'll take someone smarter than me to tell you how!
Hope it's no the capacitor because I just bought the same one last night.
« Reply #27 on: November 21, 2014, 06:32:27 PM »
Check for continuity of the windings should be a few ohms between the live and neutral terminals
and between the two terminals that the capacitor connects to.
From the casing to live neutral and capacitor terminals should be open circuit or a very high reading.
« Reply #28 on: November 21, 2014, 06:41:03 PM »
With a meter on a mid ohms range connect to the capacitor a good cap will read low resistance
and rise to open circuit in a few seconds reverse the cap and it will do the same.
This is only a rough and ready check.
« Reply #29 on: November 21, 2014, 08:32:51 PM »
Cheers, Will do
