Author Topic: element cleaning  (Read 14619 times)
Re: element cleaning
« Reply #15 on: November 03, 2014, 12:15:06 AM »
the pink one....
« Reply #16 on: December 10, 2014, 12:35:52 AM »
right, this is starting to bug me.
if i used a ch pump, and a 10" filter, how would i fill it enough to circulate freely.
would i need a resovoir,
what would i use as a cleaning agent.
how would i rinse them...
am i mad.
« Reply #17 on: December 10, 2014, 12:44:03 AM »
hows about this..
flat board. reservoir at top full of fluid. ch pump next, through 10" rig and back to reservoir (open to skim oil off)
now, the question is, am i too drunk, or not drunk enough?
« Reply #18 on: December 10, 2014, 09:08:09 AM »
Looking at this from another point of view Ged....if you set up a rig to reverse flush filter elememts like the one pictured above, is there not the likelyhood of contaminating/blocking the filter from the inside.
« Reply #19 on: December 10, 2014, 09:20:58 AM »
unless i use a detergent to break the oil down.
« Reply #20 on: December 10, 2014, 09:25:16 AM »
I'd doubt that a CHP would have enough flow/pressure to dislodge much contamination.
« Reply #21 on: December 10, 2014, 09:43:00 AM »
Instead of attemting to clean disposable elements why not bite the bullet and get something fit for purpose....like this:
http://www.ebay.co.uk/itm/10-Pleated-water-filter-cartridge-Washable-sediment-filter-High-flow-rate-10-m-/111514245654?pt=UK_HGKitchen_SmallApp_RL&hash=item19f6c45a16
« Reply #22 on: December 10, 2014, 12:33:02 PM »
one, because im bored and
b, wonder how well the grease will wash out of that....
