Author Topic: Casting concrete worktops  (Read 6205 times)
« on: October 29, 2014, 08:42:39 PM »
I use a sheet sander held against the side when vibrating smaller cast concrete work tops, also have a small Makita vibrating poker if you want to borrow it
Interested in the concrete worktops.  Done some googling on them in the past and nearly tried making them at home but  thought better of it.
Of most interest is the polishing and sealing.
Re: Casting concrete worktops
« Reply #1 on: October 29, 2014, 09:42:28 PM »
I just read up about it and watched some you tube vids, like you i fancied having a go so i talked a customer into letting me make one, turned out ok.
 i have all the bits needed to make one if you fancy a go? water fed polisher and discs, like these
http://www.ebay.co.uk/itm/100mm-4-Premium-Wet-Diamond-polishing-pad-discs-Terrazzo-Marble-9-pad-set-UK-/251334951011?pt=UK_Home_Garden_PowerTools_SM&hash=item3a84bb0063
http://www.ebay.co.uk/itm/220-230V-Wet-Polisher-For-Stone-Granite-Marble-Concrete-/171439818495?pt=UK_Home_Garden_PowerTools_SM&var=&hash=item27ea9c06ff
Vibrating poker and even some glass chippings
« Reply #2 on: October 29, 2014, 11:59:48 PM »
Looks pretty good, I'm impressed.
I really fancy having a go, but no requirement or outlet for any worktops at the moment.  Did you seal them with anything, all same travertine or marble?
That grinder ... it looks like the water is fed to the center of the spindle, is that the case?
« Reply #3 on: October 30, 2014, 07:31:02 PM »
Yes same sealer as used on granite work tops etc and yes the polisher is water fed down the centre of the spindle, no different to a grinder except for speed control really
« Reply #4 on: October 30, 2014, 07:55:03 PM »
Cool!
Looks like you cast it up side down rather than in situ?  Any reinforcement?
« Reply #5 on: October 30, 2014, 08:57:46 PM »
Cool!
Yes rebar and added some fibres to the mix
« Reply #6 on: October 31, 2014, 11:32:09 AM »
I'm guessing you cash the holes inside it, not cut them out later ?
I fancy making one for work when I sort out the new toilets, probably 8 foot long, with 2 sinks in it
I'm guessing they're crazy hard wearing and wouldn't be bothered if they get steam cleaned every day ?
(probably just lightly / at a distance)
« Reply #7 on: October 31, 2014, 08:56:33 PM »
Yep, everything done in the mould, cast upside down, concave quadrant in the corners to give round edges, half round to make the drain grooves etc
Very hard wearing but they will stain unless sealed
« Reply #8 on: October 31, 2014, 09:06:07 PM »
More interest in your worktops than bio ... I vote for a demo at BBB 2015.
« Reply #9 on: October 31, 2014, 09:12:14 PM »
Ooh I've put my mod hat on and managed to split the thread into two topics :)
« Reply #10 on: October 31, 2014, 09:15:50 PM »
We could make nice shiny concrete shoes for James?
« Reply #12 on: October 31, 2014, 09:26:25 PM »
Cor yeh! but are they bio proof so I can use'm in me shed.
« Reply #13 on: October 31, 2014, 09:31:56 PM »
It would, at this point, be fitting to add a comment about walking on water ... but I'll refrain.
« Reply #14 on: October 31, 2014, 09:33:11 PM »
http://youtu.be/zd_0CrjTrmc
http://youtu.be/xgj-7ltD6Ew
http://youtu.be/jUZ0siKbKCs
Posting those is just a cop out.  We want a demo ... do we have to have a poll on the subject?
