Author Topic: Question about angles of venturi  (Read 9558 times)
Re: Question about angles of venturi
« Reply #15 on: August 09, 2014, 11:51:24 AM »
The quickest way to feck a lathe is to use it for spinning, there are some serious loads applied to shift the metal about.
Don't do it.
« Reply #16 on: August 09, 2014, 04:52:14 PM »
Ah, right, scratch that then. I've got plenty of time to think about it now, while i weld the van up for MOT.........
« Reply #17 on: August 09, 2014, 06:32:53 PM »
When I was in the trade we referred to normal lathe work as turning. I never heared of spinning until I came on this site. What do you mean by the term. Is it it as I understand turning to use a tool mounted into the tool post to cut material off of the spinning material which is held in the chuck, or something totally different ?
« Reply #18 on: August 09, 2014, 06:49:20 PM »
« Reply #19 on: August 09, 2014, 07:00:18 PM »
Wow, thanks. That explains how lots of things are made that I always thought were pressed.
 Can see how it's brutal to tool posts tho.
« Reply #20 on: August 09, 2014, 09:31:20 PM »
I've just watched the tank dome end being made, a bit farty, the last one I watched being spun up was 40ft diam and 6" thick.
A proper dome end.
« Reply #21 on: August 10, 2014, 01:01:00 PM »
A proper dome end.
Course Jim would know, that was the time they made his trumpet!
« Reply #22 on: August 10, 2014, 01:26:45 PM »
While on the subject of shaping metal things, if spinning isn't well known, has anyone come across hydroforming?
https://www.youtube.com/watch?v=I_Z3AIFSd60
https://www.youtube.com/watch?v=ppXRMTeR2NQ
https://www.youtube.com/watch?v=y0aphiMT4VE
https://www.youtube.com/watch?v=RQE9cJApSgQ
And the engineering world's biggest nutter ...
https://www.youtube.com/watch?v=llhcATrmsBg
« Reply #23 on: August 10, 2014, 01:46:16 PM »
I hate to say it but yes, I've known about it for donkeys years.
A method use in the manufacture of brass instruments since just after the invention of hydraulics.
How about explosive forming?
« Reply #24 on: August 10, 2014, 02:09:52 PM »
I know you'd know!
Explosive forming ... yes.
If we're building a hot tub it would be a perfect tank.  A little bit of oxygen and acetylene with womble in control, no problem!
« Reply #25 on: August 10, 2014, 02:55:46 PM »
Does the Womble survive  though.
« Reply #26 on: August 10, 2014, 03:16:05 PM »
The idea is that he doesn't.
« Reply #27 on: August 10, 2014, 10:32:05 PM »
Jim doesn't hydroform, he just blows into the welded parts and up they pop.
« Reply #28 on: August 11, 2014, 12:19:33 AM »
Years of practise.
« Reply #29 on: August 11, 2014, 02:14:33 PM »
That's what you mean when you say he blows his own trumpet.  Here's me getting it wrong again. :)
