Author Topic: DIY syphon nozzle  (Read 38112 times)
Re: DIY syphon nozzle
« Reply #60 on: July 30, 2015, 09:19:59 PM »
this one may be better -
http://heating.danfoss.com/PCMPDF/BFP10-11_VDDKQ202.pdf
shows settings for one pipe, or looped opperation.
it may be interesting for you to stick a pressure gauge on it also, but possibly not, if youre never going to be pumping at pressure.
« Reply #61 on: August 06, 2015, 10:38:22 AM »
Next problem.
I have a motor EOGB M02-1-90-13 (brand new one, for cheap!) and aforementioned Danfoss BFP 11L3 pump (I understand L means left hand, rotates anti-clockwise), the two fit together but need some form of coupling to join them.
Is this the right coupling?  Are Riello and Danfoss pumps interchangable?
http://www.ebay.co.uk/itm/RIELLO-OIL-PUMP-DRIVE-COUPLING-RDB-AND-MECTRON-3000443-/191624698084
Or something like this?
http://www.ebay.co.uk/itm/BENTONE-SINGLE-STEP-DRIVE-COUPLING-C01-00-117-56802-SIMEL-AEG-B9-Pump-dog-/141607047964
(nearly a fiver for a bit of plastic ain't happening, I'd rather print one)
« Last Edit: August 06, 2015, 12:26:11 PM by Tony »
« Reply #62 on: August 06, 2015, 01:19:51 PM »
A bit of hose and two jubilee clips works quite nicely if you're not too bothered about a 'proper' engineering solution.
« Reply #63 on: August 06, 2015, 01:30:04 PM »
Hehe I like your thinking!
Sadly this is not a shaft to shaft coupling, the pump has a shaft with a flat and the motor has a recessed pocket in the back that takes some keyed coupler.
« Reply #64 on: August 07, 2015, 12:44:46 AM »
« Last Edit: August 07, 2015, 12:47:03 AM by Chug »
