Author Topic: Two stage process with no titration  (Read 12057 times)
Offline Rossey
Re: Two stage process with no titration
« Reply #15 on: July 16, 2014, 07:52:34 PM »
So you only put 20% meth of the unconverted veg after stage not the remainder if the 20% from the first stage?
Have I been overdosing?
« Reply #16 on: July 16, 2014, 08:07:58 PM »
I only use 15% methoxide on both stages, so yes you've been well over dosing.
Offline Rossey
« Reply #17 on: July 16, 2014, 08:49:05 PM »
Is that 15% of the drop out you on the first stage aswel?
Ie 100litre batch = 15lt of meth for first stage
0.1 drop out = 150ml of meth for second stage?
« Reply #18 on: July 16, 2014, 09:02:40 PM »
Since reading a post on here a couple of months ago about 15.8% methanol used, I have been aiming for around 16 to 17 % total used and have had no problems. i also find that i only get 1 or 2 ltrs of meths on the final  demeth on 100 ltr batches.
« Reply #19 on: July 16, 2014, 10:48:40 PM »
Yes but I am using ASM so no water is created in the methoxide, if you're using KOH or NaOH go for a little more, say 16 - 17% first stage and 15% second.
« Reply #20 on: July 16, 2014, 10:55:10 PM »
If you don't put the methanol in you can't get it out.
As I'm using ASM that is included in the 15% but I still get 3 - 3.5ltr back in reclaimed, mind you I do have a squirrel so demething is very efficient.
My total methanol input is around 14 - 15% including the reclaimed.
Offline Mickindashed
« Reply #21 on: July 16, 2014, 11:20:44 PM »
I make 90L batches with 11L of methoxide (koh) for stage 1 and 3L for stage 2. I get a nice clear pass on the 10/90 after the second stage and recover about 1L of methanol when demething. The input is 15.5% and the amount consumed in the reaction is 14.4%. I used to use more, but it didn't make the reaction better, it just made demething take longer.
« Reply #22 on: July 16, 2014, 11:26:58 PM »
My total Virgin meth per 100ltr batch is 10 - 11%, just love saving money.
Offline John Galt
« Reply #23 on: July 17, 2014, 07:46:23 PM »
Yes, consistent success using this method and ASM
What is ASM ?
« Reply #24 on: July 17, 2014, 07:59:47 PM »
What is ASM ?
Anhydrous Sodium Methylate, a liquid sodium based catalyst without the presents of water.
We use a 30% sodium solution the remaining volume is 99.9% methanol.
I worked out a very simple formula for its use and it's getting very popular over here.
Offline John Galt
« Reply #26 on: July 18, 2014, 04:41:47 AM »
Thanks for the info.  ASM is not an option here.  It's difficult enough getting methanol, and only NaOH is available.
So, to rephrase the question:
Is anyone getting consistent success with the no-titration method using methanol and NaOH as described in the wiki?
Offline THE-DOLPHIN
« Reply #27 on: July 18, 2014, 02:26:31 PM »
I get very good results using two stage method with koh and dry wash I do use mainly rapeseed oil only ever washed once or twice on my very first batches three years ago run b100 all year in three motors
« Reply #28 on: July 18, 2014, 04:44:37 PM »
I get consistent 2 stage results, but I overdose on catalyst as part of my process.  (Source oil need to be very dry for this!)
Offline Jmg
    • Veg site
« Reply #29 on: July 18, 2014, 06:16:09 PM »
My 2 stage results are very consistent
Glyc wash
Stage one
test
Stage 2
pass
Quantities vary in stage 2 depending on how bad the oil was to start (3 out of the last 4 batches have had a 1st stage good enough pass) with but I've never ended up doing a 3rd stage since I started doing a glyc wash. Admittedly I err on the high side with the catalyst in stage 1
Using around 17% meth overall I reckon. I probably should get more accurate measurements but if it ain't broke etc etc :)
