Author Topic: BBB 2015 hot tub  (Read 121150 times)
Re: BBB 2015 hot tub
« Reply #270 on: June 27, 2015, 07:11:09 PM »
Sure I'll bring cash.
Anyone got any veg/misfuel/flammables they can bring for the M67?  I have 40-45l of red diesel+veg mixed ready to go, will also bring some bio, not sure how long that will last.  May have to put a call out on VOD for it.
I can bring 20 ltrs of both, but I'd like the containers back at the end of the day.
« Reply #271 on: June 27, 2015, 07:19:54 PM »
What containers are they?
I've got loads of good quality clean 20/25ltr cubies you can have if your short of'm.
« Reply #272 on: June 27, 2015, 07:45:21 PM »
I've slung out all my cubies.
This is going to sound really anal, and give the Julian bashers a fieldday, the oil container is part of a matching set that stack, seal and pour really well and that I use for storing excess oil.  My other oil is all in stabbed drums which I don't want to put in the car.  The bio is in my anti-glug pourer, nothing terribly special but I'd like to hang on to it.
By Saturday there will surely be some spares cubies kicking around into which I can decant the stuff.
« Reply #273 on: June 27, 2015, 07:59:52 PM »
I will have the empties the red and veg mix is in, should be fine.
« Reply #274 on: June 27, 2015, 08:16:15 PM »
Since the water volume is much higher than initially anticipated and I'm not convinced on the flow through hose and coil will cut it I'll bring a much bigger pump so we can pump water directly in and out of the 205 the m67 is in.
« Reply #275 on: June 27, 2015, 09:35:17 PM »
To give you guys an idea, when i set my up last week i filled it with cold water from the tap all the way up to full (7500 litres).
I then started heating it. My system has a 15KW oil boiler heating the main pool flow circuit via a 100000BTU/Hr stainless heat exchanger.
It took about 6hrs running and nearly a whole 25 litre can of biodiesel to get it to a comfy 30C. So plan on a long burn to get it warm
« Reply #276 on: June 27, 2015, 10:06:53 PM »
Edit: energy calculation re-done on next page
« Last Edit: June 29, 2015, 08:40:00 AM by Tony »
« Reply #277 on: June 27, 2015, 10:37:07 PM »
I was going to ask if we needed to bring "pool fuel" as well as gambling oil and donation oil.
I have about 15L of red I been wondering what to do with, so I'll bring it along.
« Reply #278 on: June 27, 2015, 11:02:00 PM »
We can mix it all up for the M67.  Pool heating aside we can heat water for washing up too.
« Reply #279 on: June 27, 2015, 11:22:08 PM »
I think I know the answer, but I also have about 15L of veg/engine oil mix, would that be OK in the M67 (if mixed in with the rest) ?
The BBB threads seem to be a little quite this year, I get the feeling that we'll only see the usual suspects and not many new faces, shame if that's the case.
« Reply #280 on: June 28, 2015, 12:12:33 AM »
sorry, I ran off to oxford for 3 days in the middle of offering to buy a pool online and then had no internet access to reply!
I'll make sure to bring a tenner with me, and I can bring a decent amount of red too, but won;t be turning up till Friday night
also, I've got a 30m coil of 3/8 copper pipe I could bring down to help the heat exchanger along if that will help ? - but I think I;ll be too late by Saturday :-(
« Reply #281 on: June 28, 2015, 12:34:53 AM »
Julian can you reserve stock at the shop to ensure they have it in?
« Reply #282 on: June 28, 2015, 01:24:47 AM »
I imagine so but usually you have to pay by card to do so.  I missed a payment which is now covered, but the card's not working.
I'm out most of the day tomorrow, but I'll try giving them a ring before I leave to sus out the situation for Monday.  If Woking don't have one, I'll have to check other stores on route ... I think Argos also do them, but parking at their stores isn't usually as convenient as ToysRus.
« Reply #283 on: June 28, 2015, 09:19:33 AM »
I have an oil burner that we can probably setup to heat the outside of the drum too.
« Reply #284 on: June 28, 2015, 09:29:54 AM »
Can we get a spare steel drum to the field? I also have a burner which we may be able to use.  But the M67 drum is nicely painted and I was planning on insulation wrapping it.
