Author Topic: BBB 2015 hot tub  (Read 121219 times)
Re: BBB 2015 hot tub
« Reply #225 on: June 24, 2015, 11:57:57 PM »
Just caught up with all this and then told her the plan and Lynda says not to buy a pool.
Offline petep900
« Reply #226 on: June 25, 2015, 12:02:23 AM »
Flowers and chocolate it is then.......
« Reply #227 on: June 25, 2015, 12:04:58 AM »
I'm afraid it might be a case of tough titty, looks like she's gonna get one.
I've got a spare tenner under me matress somewhere so count me in.
« Reply #228 on: June 25, 2015, 12:08:58 AM »
but said the idea was to be resourceful and not spend money
« Reply #229 on: June 25, 2015, 12:09:49 AM »
Too late, wormtongue chunder started this train rolling!
« Reply #230 on: June 25, 2015, 06:44:28 AM »
Here is my one...
It is a 10' X 30" bestway. The white pipe going in a funny angle is just temporary while I wait for a few fittings to turn up.
Full to the top it holds about 7500 litres so it's important to make sure it is on a firm and level surface. Mine is on a 20' X 14' steel reinforced concrete pad 4" thick and has 4" of celotex between the pool and the concrete to insulate the warm water from the cold concrete and also make a nice smooth surface to protect the liner.
I will soon be building decking around it to make it blend in a lot more.
This is inside the plant shed,
From the left is old oil boiler (running on bio), expanson vessel for the sealed system boiler loop, high flow cartridge filter, multi-port valve to use or isolate the filter, or divert flow to waste, stainless steel heat exchanger and finally a two speed 1.5HP pump (100litres per minute on low speed, 300litres per minute on high)
Offline CHUNDER
« Reply #231 on: June 25, 2015, 08:44:52 AM »
It could be said I gave the Commie Comity a kick up the arse I was finking about dig one out and fill wiv visqueen but I can see the scence in a pre made pool now you bugers hace got to work out how to heat it  and fit it wiv jets.
« Reply #232 on: June 25, 2015, 09:46:19 AM »
At the risk of being shot down in flames ...... Gota admit, it's not really in the spirit of the BBB to buy a ready made pool is it?
What's wrong with straw bales ratchet strapped and lined with visquith/pond liner?
No digging, easy to find the bits and easy to get rid of afterwards.
« Reply #233 on: June 25, 2015, 10:20:24 AM »
I would've followed that route too, but straw bales were mooted by Chug earlier above:
And the only thing straw isn't good for is dealing with is water, so no straw bales.
I agree it's not quite the intended spirit to buy a pool, but at least that way something will get done :)
« Reply #234 on: June 25, 2015, 02:53:28 PM »
If it goes ahead stick me down for a tenner.
« Reply #235 on: June 25, 2015, 03:05:15 PM »
I'll do £10 to see Chunder in a mankini in it.
 That would be priceless.
« Reply #236 on: June 25, 2015, 03:59:43 PM »
Well we have at least nine people volunteer for funding so that'd do it
« Reply #237 on: June 25, 2015, 04:19:26 PM »
As it rather flies in the face of the original plan and Chug's already commented that Lynda's say's not to buy a pool,  it might be politic to just get the OK from them first.
I know the "buying" bit isn't an issue to all who have offered to contribute, but let's make sure everyone's comfortable with it before we go ahead.
I know he's very busy, but I've PMed Chug and if he and Lynda are happy with us doing this, I'm willing to go and buy it and drive it up to Chugs field.  Unfortunately I have to work on Tuesday, but I can do it Monday or Wednesday which ever suits Chug and Lynda.
The company sells a sheet to go under the pool for £7.99, but I suspect it's just a lump of blue tarp and not very effective.  If this goes ahead, can any one get a piece of old carpet to the field Tuesday or Wednesday?
« Last Edit: June 25, 2015, 04:25:48 PM by Julian »
« Reply #238 on: June 25, 2015, 04:34:21 PM »
Hopefully it can be seen as a group birthday present/thankyou present to Lynda, which we are more than willing to give :)
« Reply #239 on: June 25, 2015, 04:44:31 PM »
Mine, and I'm sure everyone elses thoughts exactly.
Heaven knows it only goes a fraction of the way to saying thank you for putting up with us bunch of morons over the years.
