Author Topic: Tonight I've been mostly ...  (Read 13997 times)
Re: Tonight I've been mostly ...
« Reply #30 on: May 05, 2014, 08:13:49 AM »
Next week I shall mostly be building my Prusa i2 3d printer, thanks to Julian.
Very tempted, what software are you planning to use?
« Reply #31 on: May 05, 2014, 06:02:57 PM »
Drawing wise I'm getting into sketch up, all other software will be as recommended on the build site.
« Reply #32 on: May 05, 2014, 09:47:44 PM »
Oh, and I made some bio today with no emulsion!
Well done Julian.
What did you do differently this time ?
« Reply #33 on: May 05, 2014, 09:51:37 PM »
He used gloss instead  :)
« Reply #34 on: May 05, 2014, 09:55:42 PM »
Emulsion = water based
Gloss = oil based
Bleedin' obvious innit though.
« Reply #35 on: May 05, 2014, 10:19:41 PM »
Well done Julian.
I didn't make an emulsion last time either, boy I'm getting good at this bio lark.
As toungue in cheek as your remark was ... the only thing I'm being very cautious of is not letting Frankin pump run for any longer than necessary during the 7% wash.
« Last Edit: May 05, 2014, 10:23:08 PM by Julian »
« Reply #36 on: May 05, 2014, 10:36:37 PM »
As a bit of practise, you'll need to mount the Arduino on something.  I fabricated (read ... cobbled together) something but if you want to print a more permanent mounting you could start with the attached file.  I drew this to space an Arduion board off the table so you can play with it, but it could easily be adapted for fixing to the printer frame.  I've mounted my electronics to the front right.
As the file opens, the right hand end will be the end with the power and USB connections.
« Reply #37 on: May 05, 2014, 10:47:57 PM »
Well done Julian.
It was a genuine question, not tongue in cheek at all.
« Reply #38 on: May 05, 2014, 10:50:16 PM »
Well done Julian.
As tongue in cheek as your remark was ... the only thing I'm being very cautious of is not letting Frankin pump run for any longer than necessary during the 7% wash.
Oh, sorry, my apologies.
Think I'm getting too used to people taking the mick!
« Reply #39 on: May 06, 2014, 11:12:58 PM »
And tonight I mostly built my 3d printer frame.
« Reply #40 on: May 07, 2014, 12:51:00 AM »
which one did you get ?  report back and let me know what it's like :-)
« Reply #41 on: May 07, 2014, 01:04:53 AM »
I did GET anything, I'm scratch building with a little help from Julian.
Building a Prusa i2 and hopefully a CNC plasma cutting machine later.
« Last Edit: May 07, 2014, 01:10:11 AM by Jamesrl »
« Reply #42 on: May 23, 2014, 11:18:45 PM »
Is this machine something that you could bring to the BBB Julian?
I would love to see it working
« Reply #43 on: May 23, 2014, 11:35:13 PM »
It's just about portable, but I'd rather Jim brought his in case mine gets broken!
« Reply #44 on: May 24, 2014, 12:19:49 AM »
So why is your's so fragile?
