Author Topic: active charcoal on wvo .  (Read 1412 times)
Offline zatawitono
« on: April 16, 2014, 10:03:12 AM »
what do you think ? put active charcoal on batch of waste vegetable oil . before transfer to tank reactor
Re: active charcoal on wvo .
« Reply #1 on: April 16, 2014, 10:27:15 AM »
Good question.  I've not heard of anyone trying this before.
A little reading reveals that it has a massive surface area for it's weight and will dry steam, remove chlorine from water and it appears to have a strong affinity for methanol at ambient temperatures which it releases at around 100°C.
So it might be of more use at the end of the process.  I wonder if veg oil would coat the particles, preventing them from operating?
I guess the only way to find out is to give it a go.  Be careful though, some of the powders can be extremely fine (at micron levels) so once in the oil it may be difficult to remove.
« Reply #2 on: April 16, 2014, 08:08:43 PM »
Hi all
You can get a active  charcoal filter cartridge for 10 &20" filters but it's a bit over kill for wvo, it's ok for bio but I always found wood chips better and Easier to use
« Reply #3 on: April 16, 2014, 09:58:33 PM »
I've got a 10" active charcoal filter in the garage...still wrapped in celophane. I've had it for ages.  I think I'll use it now on the strength of Julians post. I wonder how long it'll last.
