Bill ... Yes, certainly replacing the RCD is a must but it won't cover power cuts.
Jules ... how does that unit switch? It looks for all the world like a straight forward power supply I have for the LEDs in the kitchen.
Dick ... I persevered with Sketchup for the time being. I think the issues I've been having may be a bug in the software, but I've managed to produce some reasonable parts ...
This is a modified printer part to part embed and fix in place a little servo motor to automatically sense bed level.
And this in the same part, modifying it and adding a couple of cooling fan ducts.
I hadn't forgotten about it, but I'd like to hang on to your SolidWorks for a little longer until I'm confident in my abilities with Sketchup, if that's OK with you. I perhaps need to try and upgrade Sketch up to see if the "bug" is solved, but in the latest version the gearwheel add-on doesn't work ... nothing is ever simple!
