Author Topic: Current best practice with ASM  (Read 5621 times)
Re: Current best practice with ASM
« Reply #15 on: January 09, 2014, 09:51:06 PM »
c'mon nige now you finally got on the thread and all we get is smalltalk, what about the asm amounts?
Sorry Chug...my usage is pretty similar to others on this thread. When I first started I was consuming 3.5lts of ASM for a 150lt batch. Typically 3lts for stage one and the balance for stage two.
 Using a double glycerine wash as a pre-treatment I now use 2.8 as a first stage and then about 200-300ml for stage two. It's all down to stage 1 dropout.
At 4-4.5ppl I reckon it's pretty good value.
Adjustments to the amount you use on stage 1 are best judged on the amount of dropout from your first 10/90. I think, personally you should aim for 10-20% unreacted. Anymore than that I would recommend an increase in the amount you dose.
I've had some difficulties when the calculated dropout from stage one reached 40%. This normally resulted in a 3 stage process rather than a 2 stage to acheive a clear pass on the finished raw bio. Hence the aim for that in the above paragraph.
« Last Edit: January 09, 2014, 09:57:39 PM by nigelb »
Offline db
« Reply #16 on: January 11, 2014, 04:01:02 PM »
I use a base of 3 for both stages.
I start with the ASM 3 x 5 x 150 = 2250ml.
Then add methanol to total 15% of batch size,  so I'd put 20ltr in with the ASM.
BTW I never inject the methoxide under 64c, I like it 'ot.
I use exactly the same figures / amounts.
Out of interest what % conversion do you achieve on 1st stage? I achieve only 33% and this is utilizing a glycol pre treatment too.
« Reply #17 on: January 11, 2014, 08:03:37 PM »
I usually get well into the 90's percentage wise, last batch was 94%.
I will admit I'm a little anul when it come to drying my feedstock, it settles for as long as possible then it's dried at 70c using my diffuser THEN it gets a glyc wash.
I haven't a clue what it titrates at but it really is dark black.
I'm disappointed if the precentage drops to the low 80's.
