Author Topic: Loads of foam never had this before  (Read 3477 times)
« on: November 24, 2013, 06:08:27 PM »
A new experience today
Normal no tit two stage
150l.  25l 900g NaOH. - 5l and 200g
Normal pass
Demeth bio only
Transferred some nice looking bio to the settling tank then the pump started pumping white foam! There was loads of very small bubble white foam. It is in a cubie and seems to be turning back to bio. Never had that before.
Re: Loads of foam never had this before
« Reply #1 on: November 24, 2013, 06:25:28 PM »
Maybe a detergent in with the oil?  Is it from a usual source?
« Reply #2 on: November 24, 2013, 06:47:43 PM »
It was not my normal source and it was fairly manky so it could have had anything in it. Be interesting to see what the foam looks like tomorrow.
« Reply #3 on: November 24, 2013, 07:27:05 PM »
In the past I found that I got foam on top of the settling drum if the batch was quite soapy and there wasn't much meths left in the bio.
« Reply #4 on: November 24, 2013, 08:00:27 PM »
I used to get foam every so often whilst processing in my early days of making bio.  Usually when demething.  Some times it was so bad that I had foam coming out of the vent!  I've no idea what caused it and even commercial anti foam agents wouldn't prevent it.
Luckily I haven't experienced it for years now.
« Reply #5 on: November 25, 2013, 07:55:54 PM »
6 g/l on stage one?
Is that normal for you?
« Reply #6 on: November 25, 2013, 09:41:24 PM »
6 g/l on stage one?
That is what I usually use with no problems, it is old NaOH though.
Most of the foam had gone this am the rest had coalesced into soap. Still floating so I fished it out with a sieve.
« Reply #7 on: November 25, 2013, 09:52:28 PM »
6 g/l on stage one?
I'm with you on that one Glyc, that's an awful lot of NaOH & meth for a 150ltr batch 1st stage.
I'd be looking at a max of 4g/ltr and no more than 22.5lt of meth. and would expect around an 85% conversion.
I never use more than 3g/ltr and 15% meth for stage 2.
The more catalyst you use the more water you generate the more soap you get.
« Reply #8 on: November 25, 2013, 11:29:03 PM »
I've just half done a batch @ 3.5 g/l and 16%.
Usually works OK. Until one uses watery meth and leaves over night = solid caramel soap in pipework.
Feeling non-titless now.
« Reply #9 on: November 26, 2013, 08:53:52 AM »
I hear what you say re meth etc but I often get away with single stage using the higher amount. Non of our vehicles need a perfect 10/90 so if it works on one stage I spend less time on it.
I will try a 3.5 and 16% next time.
« Reply #10 on: November 26, 2013, 09:53:58 AM »
If you don't have to have a full 10/90 why not just go for a single stage 80/90% and be done with it and save money on chemicals.
« Reply #11 on: November 26, 2013, 04:31:56 PM »
I often do but sometimes do a second stage if it is cold or the first conversion is not good. With my usual oil in summer it is fine with 25l and 900 NaOH.
This oil was whites that I was donated plus some dregs from other drums. It was wet and my usual drying system got load of water out but probably not all of it. Only 20l of the meth was Virgin the rest reclaimed but I don't do a wash before demething.
