Author Topic: Thermal store  (Read 9593 times)
Re: Thermal store
« Reply #15 on: November 09, 2013, 09:48:02 PM »
GM, you should have added some insulation underneath the tank, you'd be amazed how much heat is lost without it.
I have, the pallets are full of it. You can't see it.
On closer inspection you can see it, didn't spot it the first time I looked.
Re: Thermal store
« Reply #16 on: November 10, 2013, 08:07:21 PM »
That's some cracking construction going on there, good work :)
Re: Thermal store
« Reply #17 on: November 22, 2013, 09:35:46 PM »
I was meaning on mentioning -
Someone on the navitron forum built similar.  It was a long thread, but without conclusion, as the chap moved before it was sorted.
If you do a search for "gravy" youll find it.... : /
Re: Thermal store
« Reply #18 on: November 23, 2013, 07:48:20 AM »
Cheers. I'll take a look.
Re: Thermal store
« Reply #19 on: November 23, 2013, 09:13:01 AM »
I remember thinking that the other chap's key failing was that there was no real way of keeping the oxygen out.
I see no issue with steel stores at all (plenty of people do, it seems) but i fear that you may need to seal up the system better, so as not to have the same issues?
