Author Topic: Pump woes.  (Read 6724 times)
Re: Pump woes.
« Reply #15 on: November 08, 2013, 10:21:54 PM »
I now filter my oil down to 400mic, since doing this my pump hasn't blocked, until now.
Re: Pump woes.
« Reply #16 on: November 08, 2013, 10:34:23 PM »
What are you using to get down to that sort of level?
Re: Pump woes.
« Reply #17 on: November 08, 2013, 10:41:40 PM »
Two filter socks dropped in holes on the top of my storage drum, one next to the other not inside one another.
They work quite well but are a bugger to empty as I tend to dump all my BCB's in and they get quite heavy.
Re: Pump woes.
« Reply #18 on: November 08, 2013, 10:54:13 PM »
Like this? ... http://www.biopowered.co.uk/wiki/Tips_and_wrinkles_1#Homemade_sock_filters
Re: Pump woes.
« Reply #19 on: November 08, 2013, 11:04:45 PM »
Very much the same except I brought mine from a VOD member, £2.99 each I think.
Re: Pump woes.
« Reply #20 on: November 08, 2013, 11:21:51 PM »
I use two layers of the mesh found around trampolines to filter oil from my lumpy crispy bits.  The key is time, you can dump any old crap in there, so long as it's left to drain for a decent while.  Then you get a mesh full of relatively dry bits that can be dumped in the bin, and some oil below it that makes fine bio.
Re: Pump woes.
« Reply #21 on: November 08, 2013, 11:25:25 PM »
I've been filtering to 200mic using an E-Z bucket filter for years.
Re: Pump woes.
« Reply #22 on: November 09, 2013, 04:22:38 PM »
Bit of a crap idea really...ah well!
I suppose Lorretta was right all along ;) Tell her I take it all back 8) ;D
Hmm, when she isnt looking it goes in "as collected"!   :)
