Author Topic: Quiet in here!  (Read 4357 times)
Re: Quiet in here!
« Reply #15 on: October 22, 2013, 08:07:10 PM »
I've been busy sourcing and sorting out my new car..
I went to see Glycer-rides on Saturday to take delivery of a set of wheels for winter rubber and this coming Saturday I'm off to see Keith and Lorretta. Not seen them for ages...can't wait.
Not brewed for about a month now. Must get round to it soon....just to stay on top.
Re: Quiet in here!
« Reply #16 on: October 22, 2013, 08:13:39 PM »
i have been mainly spending all my money fixing the generator and charge controller.
This sounds interesting. Any more details?
Re: Quiet in here!
« Reply #17 on: October 22, 2013, 08:54:17 PM »
Just been contacted by the widow of someone i showed round a few years ago, she wants me to collect all his brewing paraphernalia, for the life of me i cant remember the guy :o
Re: Quiet in here!
« Reply #18 on: October 22, 2013, 10:18:59 PM »
I got a gly wash and first stage done tonight.
Also took my camera and took some pics of the new defuser, I'll start a new thread for that though.
Re: Quiet in here!
« Reply #19 on: October 23, 2013, 12:40:41 AM »
the genny is a chinese copy of a yanmar l100 with a4kw alternator on the end of it.
it first started when i inadvertently put some contaminated red diesel in. had some water in it. i hadn't used the genny for around 6 months. i only use to top up my battery bank. the solar panels have been  keeping the panels on float all summer. 3 weeks of Cornish fog dragged them right down.
 genny wouldn't start. fitted new pump. still no joy. checked the timing. adjusted  by different sized shims. still no joy. took it to a mate as i am in a field and trying to fix it in the rain wasn't getting me anywhere but very wet. he took the head off  reground the valves, still no joy. only thing left was the rings being gummed from using veg oil. took it all apart.  not easy as we  had to dismantle the alternator first. got the piston out. rings stuck to the piston. new rings honed bore. put it all back together. fired up straight away. with his bill plus the parts to worked out about the same as buying a new one. should have asked him for a quote first.
now the charge controller is broken as well. been putting the dump load straight across the batteries flattening them in a couple of hours. i now have them back up to something like a decent charge.
i could have done all myself but was panicking about killing the battery bank. would cost 2 grand to replace that.  still done now. must run the genny a bit more to stop it happening again. for the times i use it i will stick to red from now on.
in hindsight spending £500 on more solar would have been better, but a bit late now. never mind its only money.
Re: Quiet in here!
« Reply #20 on: October 23, 2013, 07:13:37 AM »
What charge controller are you using, and what voltage does your battery bank run at?
I only ask as I'm in the middle of a very similar endeavour.
Re: Quiet in here!
« Reply #21 on: October 23, 2013, 11:01:58 AM »
hi i am using a morningstar ts45. cant say i am that impressed as this is the second one to die in 5 years. they do come with a 5 year warranty though. the outback ones  have a good reputation but are a lot more expensive.  the dump load is some nichome wire wrapped around the elements of an old electric fire. it does howl a lot when the charge controller is dumping power, so keep it somewhere where you cant hear it.
the battery bank is 8 rolls s430 6 volt  deep cycle batteries run in 2 banks of 4 for 24 volts 800 amp hours they are around £240 each from bardens. had them for around 5/6 years now. seem to be the best around for the price.   the bank runs at 24 volts, mainly because that is a good compromise between wind and solar 48 would be better but the inverters get a lot more expensive. the charge controller will work at 48 volts.
« Last Edit: October 23, 2013, 11:06:54 AM by photoman290 »
