Author Topic: gate valve verses ball valve  (Read 6261 times)
Re: gate valve verses ball valve
« Reply #15 on: September 18, 2013, 09:30:42 AM »
Quote
rubbers in the jp pushfit expands and leaks, used it when pumping out the bio, leaked after just a few batches
Best option is to use brass compression fittings on JG Speedfit or Hep20 pipe.
Offline BANDIT2
« Reply #16 on: September 23, 2013, 10:49:47 AM »
Agreed, and don't forget inserts :)
« Reply #17 on: September 23, 2013, 11:02:50 AM »
Yes sorry I should have mentioned that the hep2o that I've used successfully for bio transfer for years is all plumbed in with brass compression fittings + pipe inserts.  I really don't see a problem with it's use for transfer and settle tanks and things like that, in fact I plan to use it extensively on my new settle tank arrangement.
One chap I know used it for part of his processor main loop pipework, despite my misgivings it seems to have survived over a year - not sure I'd be that happy dewatering at 105C with it though!
« Reply #18 on: September 23, 2013, 12:14:57 PM »
it is rated to 92c but will withstand up to 114c for short periods. If connecting to a copper cylinder then use 1 meter of copper pipe because of residual heat.
Well that's what the manufacture says.
Offline BANDIT2
« Reply #19 on: September 23, 2013, 01:49:18 PM »
It survives well in veg too, I made a heater coil out of it and use it to warm up my veg settling tank for glyc washing and the like.
plumbed into my boiler circuit with by pass valves.
