Author Topic: Tony's post on removing soap from a settling tank.  (Read 2623 times)
« on: August 23, 2013, 02:49:56 PM »
Can't find the original post, so starting a fresh ...
Since I last cleaned my settling tank I've been titrated acid washing every batch.  Had some time spare whilst dewatering today, so I thought I'd give it another clean out.
Surprise ... no soap, just a shallow sludgy type of layer (similar to the intermediate layer I posted on this page recently ... http://www.biopowered.co.uk/wiki/Water_washing_titrated_acid_method) which, if the tank was cone bottomed, would have drained very easily through a valve.
So acid washing could save you a great deal of digging.
« Last Edit: August 23, 2013, 02:51:45 PM by Julian »
Re: Tony's post on removing soap from a settling tank.
« Reply #1 on: August 23, 2013, 05:23:36 PM »
Are you using the conc acid or the battery acid? How much on average are you using?
« Reply #2 on: August 23, 2013, 06:04:22 PM »
Still using up my old supply of conc.  It varies a little bath to batch but on the last few batches I've used 15 - 20 ml.  So what I picked up at the BBB is a lifetimes supply!
« Reply #3 on: August 23, 2013, 06:11:27 PM »
Thinking about this, I've just removed the "never overflowing drain" pipe from the tank.  Think I'll use the hole to install a 15mm drain valve similar to this ... http://www.biopowered.co.uk/wiki/Draining_a_plastic_barrel
Suppose I should be praticing what I preach!
« Reply #4 on: August 25, 2013, 12:22:24 PM »
I've added a little text to the titrated acid wash page to reflect the above.
« Reply #5 on: August 25, 2013, 04:07:18 PM »
Ah you can keep it, my process is going to remain dry :)
