Author Topic: Cue the 2001 Space Odessy music!  (Read 7256 times)
Re: Cue the 2001 Space Odessy music!
« Reply #15 on: July 29, 2013, 10:30:07 AM »
« Reply #16 on: July 29, 2013, 10:34:37 AM »
Another idea.
What I could do is take the 1" bottom port and run it to a sealed container below the tank.  Any soap should surely settle into the container rather than accumulate in the tank?  The question is whether I'd trust a 25l plastic container to remain sealed through a tank fitting in the cap, and not dump the batch out onto the floor.
« Reply #17 on: July 29, 2013, 12:24:14 PM »
Another idea.
I say it would burst the container.
Why can't you just get in the tank with a shovel every now and again?
« Reply #18 on: July 29, 2013, 01:29:41 PM »
Another idea.
The tanks measure 24" by 30" on the base and 48" tall, which would be a long way to lean down, especially if lifted off the ground on concrete blocks (though I could cut enough off the top to reduce the tank to say, 36").  It just seems a shame to cut the tank down really.
« Reply #19 on: July 29, 2013, 01:34:42 PM »
Ah, they looked a lot bigger than that.
Could you fit a big port on it, then have some device to tilt the tank once in a while?
« Last Edit: July 29, 2013, 01:36:46 PM by greasemonkey »
« Reply #20 on: July 29, 2013, 01:46:57 PM »
Tony I have a 2" valve I have no use for.
« Reply #21 on: July 29, 2013, 02:09:30 PM »
That's very kind of you Mark, I don't know where I'm going with this one yet so that's a useful option.  Is it a lever or gate valve?
What I'm thinking of is that if I put a takeoff point (for drywash/storage) a few inches up the side of the tank, then there is likely to be a layer of soap, with a layer of bio above it, so when draining soap the valve would need to be shut sharpish otherwise I can see a lot of bio rushing out of a 2" hole!
I'm wondering about how heat sat on top of soap will soften it, might have to experiment with existing batches in drums, poke a stick in and see how hard the soap at the bottom is (annoyingly, did a batch yesterday I could've done that with!)
I suppose you could stir the tank when hot bio is added to mix it in a bit (it'll soon settle again) but the idea of stirring hot bio with Meth fumes coming off doesn't sound wise to me at all.
« Reply #22 on: July 29, 2013, 06:13:23 PM »
It's a leaver valve, a bit stiff probably due to lack of use but should free off with a drop of oil.
« Reply #23 on: July 29, 2013, 06:20:38 PM »
Why not just have an agitation paddle in there. After a few batches of bio have settled, drain out the bio and put in 100 litres or so of hot water and switch on the paddle.
After a few hours, open the big valve and let out the very soapy water down the drain.
« Reply #24 on: July 29, 2013, 09:42:00 PM »
I've got no running water in the outbuilding and drains are a good 20m away.  Nothing that couldn't be cured with pumps though - like the idea in principle.
