Author Topic: newbie needs help please  (Read 8575 times)
Offline craig
  • Wana Blow Somat Up
    • web design
Re: newbie needs help please
« Reply #15 on: July 31, 2013, 09:27:58 PM »
That's good to know, it nearly got binned ;D.
This might be a silly question but just learning.
OK i don't have a processor yet
the last tester i did was 25 liters in a plastic drum left it overnight and the bottom 2" set solid
leaving me with bio above this is what i have been washing and it seems to be OK 3/27 good.
is it OK to carry on doing it this way until i get a processor  :-\
yes i know it would be easier to drain the glycerin while liquid but as i cant see through the bucket
i don't know how long to leave it and how much to drain off.
and what is the 2 stage no titration
« Last Edit: July 31, 2013, 09:30:36 PM by craig »
« Reply #16 on: July 31, 2013, 10:57:00 PM »
Two stage reaction, read this
http://www.biopowered.co.uk/wiki/Two_stage_process_with_no_titration
You can make bio in a bucket, but it's for safety reasons we build dedicated reactors.
Offline craig
    • web design
« Reply #17 on: July 31, 2013, 11:29:54 PM »
Hi Mark
I will be making a reactor tank when i know what I need.
I have started to make a wash tank that should work well :-\
As for 2 stage no titration Hm-mm maybe at a later date after more practice
« Reply #18 on: August 01, 2013, 07:53:14 AM »
doesnt 2 stage take away the need to practice, makes life easy...
Offline craig
    • web design
« Reply #19 on: August 01, 2013, 08:14:46 PM »
It makes life easy when you know what your doing to start with.
« Reply #20 on: August 02, 2013, 10:49:51 PM »
It's easier and more relyable than titration, it just sounds confusing.
« Reply #21 on: August 02, 2013, 10:53:59 PM »
Two stage no tit, is simpler, says the man who has only done one batch.
Titration sounds like a right fiddle to me, and requires more kit, and a greater understanding.
Understanding is all well and good, but getting bio out is what counts.
A no tit process is simple, just don't do a soap test at the same time as the conversion test.............
« Reply #22 on: August 03, 2013, 01:42:46 PM »
circulated in the processor yesterday for about 4 hours and took a sample. was clear this morning with a dark brown drop out, so have circulate for 90 mins then put into settling tank.
now its just wait and see.
am going to make spray bar this afternoon, just in case!!!
Offline craig
    • web design
« Reply #23 on: August 04, 2013, 10:20:56 PM »
OK guys i need some more help :'(
just did a 50/50 water & bio shake test.
fully separated in 5 Min's
now i have 1/2 bio and 1/2 milkshake :(
how the _ _ _ _ do i get it clean.
Offline craig
    • web design
« Reply #24 on: August 04, 2013, 10:27:25 PM »
and what colour should it be?
a sample in a syringe it looks a golden colour
but in a demijohn it looks very dark.
« Reply #25 on: August 04, 2013, 10:58:38 PM »
In a 50/50 the bio will always pick up water, especially if there's even a tiny bit of soap around.  It will be a dirty orange juice colour and is quite normal.  It's typical of the colour you get when water washing.
With the 50/50 you are only interested in the colour and clarity of the water.  It should be clear, any white opaque tinge indicates that you've washed soap out of the bio.
If you leave it long enough, unlidded the bio will eventually dry and can be decanted off or added to the next batch on the wash cycle.
Is the demijohn the trial batch?  If so you only need to take a half jam jar sample for the 50/50 test.
Offline craig
    • web design
« Reply #26 on: August 04, 2013, 11:21:53 PM »
I thought it was washed well it cleared to a transparent golden colour not cloudy orange juice anymore.
so i decanted to a demijohn then took a 100ML sample bottle to 50/50 shake test.
i could immediately see it separating but the water is a white milky colour
if i start washing again will it eventually get rid of the white water
Its all new to me.
« Reply #27 on: August 04, 2013, 11:32:31 PM »
Have a read of this page ... http://www.biopowered.co.uk/wiki/Water_washing.
Regardless of the method of washing, the bio and water colours will be the same in each case.
If you have a milky 50/50 then you still have soap in the bio, despite it looking clear.  You can just leave it to settle for a week or two.  Over time you'll see a light, white/grayish gel type layer form at the bottom ... that's the soap.  Or you could try washing again.
Don't be in too much of a hurry to get results, time and gravity are often your best friends when making bio.
Offline craig
    • web design
« Reply #28 on: August 04, 2013, 11:48:09 PM »
Silly question Julian :-[
do I leave it to settle with water in it or do I drain it off
« Reply #29 on: August 04, 2013, 11:56:23 PM »
If you are going to let it settle there's probably not much point in draining the water now as you'll only get more water dropping out of the bio.
You should see a layer of clear bio forming at the top which will get larger as it drys.
