Author Topic: GL or Appleseed?  (Read 7716 times)
Offline Rossey
Re: GL or Appleseed?
« Reply #15 on: May 31, 2013, 03:16:29 PM »
And do I need an educator?
What subject do you want to learn?  ;)
Or do you mean an eductor?
How to make bio lol
Stupid auto correct
Offline thewormman
« Reply #16 on: May 31, 2013, 06:57:04 PM »
I'd go for both then I know I needed all the help I could get and I still do ???
« Reply #17 on: May 31, 2013, 07:13:30 PM »
What do I need to control the immersion temperature?
Can I just use the normal thermostat or or I need a PID?
I'm gonna use a copper cylinder which will the immersion pointing up from the bottom, will a 11" be sufficient?
Would a 50lpm pump be powerful enough?
You can use either to control temperature, but in my humble opinion it's a no contest in favour of a PID and SSR setup.  Way more accurate control over temperature and it will control to higher temperatures than the standard immersion thermostat.  Some PIDs have a high temp alarm which can be a used as a high temperature shut sown.
11 inch  immersion elements are usually bent double, however it's the wattage which dictates how well it will perform.  Most standard immersions are 3Kw, but defiantly stick with the 11 inch version for safety.
I have a 40lpm Leo pump on my processor, but I run it in parallel with a little Mono MS (when it's not leaking) but I recon the system would benefit from a still higher flow rate.  My venturi although sized for a 40 lpm pump works far better driven by a higher flow.  So I'd say go for a 60-80 lpm pump if you can stretch to it.
I've not got an eductor, so can't comment, but a bigger pump will go a long way to doing the same thing.
Offline Rossey
« Reply #18 on: May 31, 2013, 10:05:41 PM »
« Reply #19 on: May 31, 2013, 10:08:40 PM »
An eductor is not a necessity but it does help reduce reaction times,
that said with the two stage reaction it's hard to quantify as most (myself included) just run each stage for 1hr.
