Author Topic: Mono pump, he go bugger up ... again.  (Read 6667 times)
Re: Mono pump, he go bugger up ... again.
« Reply #15 on: June 01, 2013, 08:59:46 PM »
So, the saga continues ....
Pulled the MS appart again today to reveal exactly the same problem as last time, a lump of brass embedded in the graphite rotating half.
After cleaning up, this is what was removed, note the score marks in the brass, static half.
On inspection the brass washer which sits between the spring and the 'O' ring in the graphite seal half was slightly chewed up and rough with sharp edges.  Similarly the ends of the spring were quite sharp.  Given the state of the washer I could only assume that the brass fragment lodged in the graphite came from here.  That said there's no reason for the washer to get chewed up ... everything on the rotor rotates with it!
Anyhow, I decided to replace the brass washer (which was quite soft) with a steel item, so one was turned on the lathe.  The edges of the new washer were broken using a wire wheel on a bench grinder.  The ends of the spring were gently re-flattened on a grindstone and the external edges slightly champhered.  The edges were then given the same treatment as the washer.  Again the two halves of the seal were sanded and linished.
These are the components which went back in the pump.
I tested it for a couple of hours this afternoon and not a leak in sight ... Ooo, that strange feeling of deja vous.
If this lasts I'll update the wiki page.  I think it's tempting fate to do it straight away!
« Reply #16 on: June 07, 2013, 07:03:04 PM »
Good news ... the seal has held up for quite a bit of oil transferring, a couple of hours dewatering reaching over 100°C, a full process and a demeth at 70°C.
So I hope it will be safe to add the comments to the wiki.
« Reply #17 on: June 10, 2013, 08:08:15 PM »
Just added a 1:1 drawing of the gasket to the MS page.
Could someone confirm the pdf works ok please ... I don't have much luck with pdfs on here?
« Reply #18 on: June 10, 2013, 08:21:01 PM »
It opens for me, but i dont know if it would print to the right size.
I think it would be good to have the OD listed, as then a user could print it, and check - at the moment, the only way of checking would be to physically measure the pump parts.
« Reply #19 on: June 10, 2013, 08:31:39 PM »
OD is 140 if you wouldn't mind checking it, and good idea, I'll add it to the page.
« Reply #20 on: June 10, 2013, 08:33:54 PM »
Added the dimension ... await your confirmation, thanks!
« Reply #21 on: June 10, 2013, 09:15:45 PM »
Will check it tomorrow - just about to go to bed (and its only 20 past 9 - ughh!)
