Author Topic: Newspaper clears bio ... not sure I believe this myself!  (Read 18196 times)
Re: Newspaper clears bio ... not sure I believe this myself!
« Reply #15 on: May 07, 2013, 11:36:38 PM »
I'd love to help with this experimentation...but I don't know how to make cloudy bio. ::)
I know what you mean Nige, what is this cloudy stuff they speak off.
One day we may have the pleasure of welcoming you both to the wonderful and fascinating world of fallible mortals.
« Reply #16 on: May 07, 2013, 11:42:27 PM »
if the bio is clear fresh (hot) out of the reactor
and then it clouds up
whatever fats the cloudyness is made from must be floating around in the bio, and then group up and join together to form tiny fat lumps which we see at cloudyness
maybe it's easier (less energy) to form fats on the surface of the newspaper than it is for then to stick to each other ?
and/or it's easier to bump into and stick to the massive surface area of the newspaper than another tiny fat molecule ?
you could test a thin slither of newspaper and see what happens, does it totally clear the bio, and is there a residue left on it ?
could also try cardboard, a plastic bag, a bit of wood, broken glass, some kind of cloth/wool/denim etc... if you've got a dog, comb it then stick some of it's hair in there ?
(just trying to cover all biases with materials/surfaces)
if you can narrow down exactly what's going on, it would be much easier to adapt it into your process / make it more efficient
if it is the rough surface helping the fats form like I'm guessing, then newspaper probably will be one of the best things for it because it has a rough surface...
if that's right, then it would be pretty easy to roll up some newspapers into some drain pipe and pump the (cold) bio through... not sure how fast you could pump it... I can't decide if using lots of newspaper tightly packed in will mean you can pump it through pretty fast or not... still thinking on that one   ;)
 Interesting theorys.  Bio was cloudy when hot and stayed that way during cooling and remains the same at ambient.   As with my answer to Jim, if simply dangling some newspaper in the settling drum works, why do anything more hitec than that.
« Reply #17 on: May 08, 2013, 12:04:51 AM »
I think if you just hang it in the tank it'll fall apart once it gets soggy
« Reply #18 on: May 08, 2013, 12:27:58 AM »
It doesn't go soggy in bio like it does in water, it retains it's strength.
« Last Edit: May 08, 2013, 12:29:55 AM by Julian »
« Reply #19 on: May 08, 2013, 04:34:21 AM »
freaky! I didn't expect that, I thought the weight of the oil would pull it apart!
I wonder if it's a bit like wet cloths being stronger than dry ones?
« Reply #20 on: May 08, 2013, 10:30:31 AM »
No thanks, I think we'll just sit atop Olympus watching you mere mortals.
« Reply #21 on: May 08, 2013, 01:28:55 PM »
The thirteenth God - Coppabasha, God of Self Abu...err Worship?
« Reply #22 on: May 08, 2013, 01:45:26 PM »
That's heresy, beware the inquisition AND a bolt of lightening, you non believer.
« Reply #23 on: May 08, 2013, 01:51:19 PM »
I the real world of Gods I was thinking more along the lines of  Hephaestus
Here's and avatar for you, Jim.
http://www.palmergroup.co.uk/Bio/avatar_hephaestus.jpg
« Reply #24 on: May 08, 2013, 01:54:31 PM »
That's better, I bit of respeck at last.
« Reply #25 on: May 08, 2013, 03:09:33 PM »
Well that's the kind of thing you catch if you hang out with ladies of ill repute!
« Reply #26 on: May 08, 2013, 04:18:08 PM »
Enjoy ... it won't last.
« Reply #27 on: May 08, 2013, 07:14:31 PM »
They've got pills for it now, I'm just getting over a nasty bout of it.
« Reply #28 on: May 08, 2013, 07:40:36 PM »
.....not while I'm water washing you wont.
« Reply #29 on: May 08, 2013, 07:53:29 PM »
Proverbs, Chapter 16, Verse 18 ...  Pride goeth before destruction, and a haughty spirit before a fall.
As with Pete's Jee, Je, Jeeee (American car) ... I'll remind you you said that one day.
