Author Topic: Glog briquette failure!  (Read 17438 times)
Re: Glog briquette failure!
« Reply #30 on: May 08, 2013, 09:34:29 PM »
What would happen if you let the saw dust soak in the glyc, say for 48 hours, or a week even, and then compressed it? Surely it would retain more glyc that way. By just mixing it and compressing it, there is only a thin layer of glyc on the surface of the sawdust particles, whereas it would be saturated with the stuff after a while.
« Reply #31 on: May 08, 2013, 10:00:24 PM »
The saw dust had been mixed for at least two weeks possibly longer.  This process is not really suitable for glogs, they need a means of gently compacing the mix and then confining it in something that won't leak.
« Reply #32 on: May 08, 2013, 10:08:35 PM »
I would imagine glyc soap burns? maybe we could add caustic so it sets solid like glyc bar soap, then it wouldnt need any packaging
« Reply #33 on: May 08, 2013, 10:14:42 PM »
Hmm, I would imagine glyc soap wouldn't burn.
« Reply #34 on: May 08, 2013, 10:16:10 PM »
Like the train of thought but I think the idea derails when you consider putting it on a fire, wouldn't the solid soap melt ... not that I'm a soap expert you understand.
« Reply #35 on: May 08, 2013, 10:26:51 PM »
what is it you are trying to achieve Julian?
longer burning logs?
or just experimenting?
other?
« Reply #36 on: May 08, 2013, 10:32:09 PM »
An easier, less messy, less time consuming way of making them ... pretty much the Holy Glog or should that be Grail?
« Reply #37 on: May 09, 2013, 08:04:47 PM »
I wasnt suggesting burning solid bars or soap, more like adding some caustic to help solidify the glyc logs, if it would work
Offline whatarascal
« Reply #38 on: May 10, 2013, 10:43:57 AM »
Ahh that would be newspaper then.
I have been been there done that with shredded paper a ten ton press carpet tubes specially made bricket makers you name it.
What a waste of effort.
Just mix using little glycerol let soak then wrap in nespaper.
The act of wrapping one packet takes less than 60 seconds
One day its all gonna go off
