Author Topic: Transit filter problems  (Read 16225 times)
Re: Transit filter problems
« Reply #60 on: May 15, 2013, 10:30:05 PM »
If your using Banjos, tightening them up without twisting the pipe is not a issue. Maybe have one hose tail, joined by pipe to a banjo. The banjos seem expensive. I'm sure there are water fittings that will fit, for a lot less money.
Could definitely join more than two together.
Getting banjos that come out on a 90 degree would be better. The ones I found were all straight.
« Reply #61 on: May 15, 2013, 10:57:34 PM »
Is this any good Alan? Same idea, different filters.
http://www.ssldieselparts.co.uk/double-filter-head-type-p-704.html
« Reply #62 on: May 15, 2013, 11:01:14 PM »
shit that is a bargain!
Price:  £9.00 (ex vat)
£10.80 (inc vat)
« Last Edit: May 15, 2013, 11:03:17 PM by SquidWard »
« Reply #63 on: May 15, 2013, 11:05:37 PM »
It cheap, but it does need two bowls, and the bolts and washers to attach them. Haven't looked at the prices of them yet.
Needs the filters too.
Bowls £4.79 inclusive
Bolt £4.20
Still cheap enough. Roughly £28, plus filters.
Very cheap actually. My single was £25
« Last Edit: May 15, 2013, 11:09:56 PM by greasemonkey »
« Reply #64 on: May 15, 2013, 11:10:27 PM »
yeah true all adds up
« Reply #65 on: May 15, 2013, 11:37:28 PM »
« Reply #67 on: May 15, 2013, 11:45:25 PM »
That looks a good co. That is who I had my parts off. They don't show half that stuff on E bay.
« Reply #68 on: May 16, 2013, 02:54:51 AM »
the problem is they only do the Lucas/cartridge type with the bowl on the bottom (which makes loads of mess when you chance a filter, plus it's a bit more fiddly)
the bosh ones they used to do are the type where the bowl on the bottom is part of the filter, so you just twist one filter off and twist the new one on, no mess etc..
I got a twin bosh one from them before.... and emailed them when I needed another but they didn't do them any more :-(
