Author Topic: Acetone additive  (Read 12367 times)
Re: Acetone additive
« Reply #15 on: May 17, 2013, 10:32:18 AM »
I've not been adding as much as that (0.3ml/l). I'll try a stronger dose.
Adding around 0.75ml/lt is a starting point and may have a positive effect BUT there's a point where Acetone  will reduce MPG.
I started at 0.75ml, I'm keeping an eye on mpg as I increase the dose to a point where nothing more happens.
I do a regular road trip up to my boat and back where the MPG test take place, same route same distance every time.
« Reply #16 on: May 17, 2013, 12:05:48 PM »
I wonder, like adding petrol to WVO, whether the small molecules of the acetone help with biodiesel viscosity as well as atomisation?  Would it work just as well with IPA or is there something special about acetone?
« Reply #17 on: May 19, 2013, 01:22:18 AM »
I'm running 0.8ml/l now, if anything it feels like it has lost some power.
Offline RichardP
« Reply #18 on: May 19, 2013, 08:58:41 AM »
I've been using about 1.5ml/l for sometime now, and it does give a noticeable improvement to both mpg and engine responsiveness.
It's more noticeable on the 206, without acetone it feels quite sluggish, with acetone it's like a new car.
« Reply #19 on: May 19, 2013, 09:35:37 AM »
I wonder why mine feels sluggish on less then? Maybe Acetone taking the paint off something and it ending up in the filter?
Offline RichardP
« Reply #20 on: May 19, 2013, 12:43:37 PM »
Probably because 0.3ml/l is no where near enough to have the required effect. A bit like drinking American beer when you want to get drunk.
« Reply #21 on: May 19, 2013, 01:07:17 PM »
It was fine at 0.3ml/l, but feels sluggish at 0.8ml/l
With you on American "beer" though, if you can call it that.
Offline RichardP
« Reply #22 on: May 19, 2013, 04:15:57 PM »
But you said at .3ml you couldn't see any difference, and you were going to up it?
I wouldn't be surprised if the ideal dose is dependent on the feedstock used
I was being generous with calling it 'beer'.
« Reply #23 on: May 19, 2013, 06:02:38 PM »
What about trying Hifly's Rocket fuel Cidre.
« Reply #24 on: May 19, 2013, 06:58:46 PM »
How do we stand with this in terms of tax?
