Author Topic: 2 off 500L stainless processors  (Read 16682 times)
Offline bertle
Re: 2 off 500L stainless processors
« Reply #30 on: May 05, 2013, 10:05:41 PM »
Will do!  Got the lintels on the french doors to the shed today along with a few more courses of bricks and blocks on the inner leaf.  As soon as I get tidied up, I'll take some pics.
I have got a set of "how it was made" photos to post up at some point.
« Reply #31 on: May 05, 2013, 10:20:51 PM »
I think the wiki would benefit from a few "members processor build" pages ... if you fancy a go.
Offline bertle
« Reply #32 on: May 06, 2013, 10:39:05 AM »
Probably a bit beyond the average home builders equipment, you will see what I mean when I put the piccies up.
« Reply #33 on: May 06, 2013, 04:46:01 PM »
Not beyond my equipment matey.
Offline 1958steveflying
« Reply #34 on: May 06, 2013, 04:52:31 PM »
Are you an average home builder Jim ?
« Reply #35 on: May 06, 2013, 04:56:47 PM »
Of course I am, I used to build plants at home before I moved.
Offline bertle
« Reply #36 on: May 06, 2013, 08:17:29 PM »
What I was trying to say was that the "how I did it" pictures show the use of lots of expensive equipment not available to the average home builder, and as such are not representative of how it could be done in your garage. I think most people would struggle to deal with 2mm stainless sheet and 1" nominal bore stainless pipe bending. I was only offering it up as a point of interest for others. If someone wants to put it on the wiki feel free.
« Reply #37 on: May 06, 2013, 08:19:23 PM »
Aha! a bite, gotcha.
Offline bertle
« Reply #38 on: May 06, 2013, 09:04:47 PM »
Here you go.
First off cutting the developed flat patterns for the cones on the laser, complete with etching the bend lines on.
[imghttp://i250.photobucket.com/albums/gg248/bertle500/IMAG0215_zps2de02a57.jpg]http://[/img]
Pressing the cones (not me, I was taking the pictures).
Rolling the main tank bodies
A spot of TIG welding
Main body, inner cone and extension to take the outer cone
And with the second cone on
And there you go pumps on, legs on and plumbed up. The venturi has now been moved up the pipe due to popular demand.
« Reply #39 on: May 06, 2013, 09:17:33 PM »
I gotta ask Andrew, why 2mm?
« Reply #40 on: May 06, 2013, 09:19:14 PM »
That's very very cool machinery that you get to play with all day... soooo jealous ;-)
« Reply #41 on: May 06, 2013, 09:22:54 PM »
He don't play wiv'm, he gets others to do that and just stands there taking piccies.
THEN he says Look what I'VE made.
« Reply #42 on: May 06, 2013, 09:31:08 PM »
Oh Boy! Some serious kit there.
« Reply #43 on: May 06, 2013, 09:42:01 PM »
I never ever want to see your VW!  ;D ;D ;D ;D ;D ;D ;D
Offline bertle
« Reply #44 on: May 06, 2013, 09:55:50 PM »
I made them out of 2 mm for several reasons. Firstly we are talking about a 500L free standing vessel which is not to be taken lightly. I could have done then 1.5 mm but I would have wanted compensating plates on the leg mounts and pipe entries. Also the cones are welded on corner to corner, which would not be as easy in 1.5 and you might start thinking about putting a spun edge on to compensate. The cost difference in material is not that great and the result is a stronger, easier to make tank which ultimately if you have the gear is quicker to make in 2mm than 1.5 mm.
As for getting other people to do the work I can assure you I can and indeed did do them. I got my cousin to help out as we made 2 of them there was a lot to do so I employed a little help. My actual job is running the machine shop and writing the programmes for the cnc machines so my fabrication and welding is quite good for a machinest don't you think?
