Author Topic: I've finally managed it  (Read 18023 times)
Re: I've finally managed it
« Reply #15 on: April 26, 2013, 10:11:45 PM »
And, as far as I am aware, adding alkaline compounds to engine oils has been phased out as the introduction of ULSD has stopped the formation of acidic compounds in the combustion process.
Interesting stuff. What was crossing my mind is, does WVO or bio produce acids when it burns? Would there be a case for adding some kind of alkalizing agent to the engine oil?
Nice work with the lister by the way. Always nice to see something  like that running. I'd find it re assuring to have a way pf producing electric, and plenty of fuel for it, just in case the grid starts going down on a regular basis in years to come.
« Reply #16 on: April 28, 2013, 12:12:05 AM »
Nice one James, it's good to see them working eh, mine has been sat in my field, run regularly just to stand at look and listen to it but otherwise no useful work....one day!
« Reply #17 on: April 28, 2013, 03:42:05 PM »
if you need a back up cheap chinese genny i have a very good contact. wont link to it here as i think advertising is against forum rules. email me or message me. they are cheap, friendly, very knowledgeable  and do all the spares as well. not far from you in coleford.
« Reply #18 on: April 28, 2013, 04:02:29 PM »
Cheers Bob. Getting my own off grid power supply will be something I will look into in the future. I'm convinced in a few years time the lights will start to go out, and it's going to be the rural areas that get hit first. Right now, I've got a few different projects on the go, and they have all come to a halt from lack of investment.........
« Reply #19 on: April 28, 2013, 06:03:10 PM »
I agree. I have a start o matic lister that is going to be overhauled then used as a grid tie and power for brewing and workshop with the wiring to backup the house and cabin if/when the power goes off. 8.1 so even more heat at 4kW output.
Dick
« Reply #20 on: April 28, 2013, 06:30:34 PM »
Just to clarify matters ... we are trying to avoid/prevent/outlaw advertising, but recommending/warning of a product of which you've had experience, good or bad is fine, as is posting a link to it.  If you feel it merits it, list it on the members "Equipment and services directory" page here ... http://www.biopowered.co.uk/wiki/Equipment_and_services_directory
« Reply #21 on: April 28, 2013, 06:47:31 PM »
« Reply #22 on: April 28, 2013, 06:49:09 PM »
have added a link to the generator supplier. probably made a pigs ear of it as it is my first contribution to the wiki.
« Reply #23 on: April 28, 2013, 06:59:33 PM »
No, not a pigs ear ... good as a first attempt.
I've just moved it to the equipment section and did a little tidying.  Could you go back in and add three or four squiggles (can't remember which ... you'll have to experiment) in place of where I put Posted by photoman290.
That should add your forum name and the time and date.
« Reply #24 on: April 28, 2013, 07:02:10 PM »
Just checked and it's 4 squiggles for name and date, thus ... ~~~~
Three squiggles is just your name.
« Reply #25 on: April 28, 2013, 08:08:52 PM »
Looks like it is starting already. Electric has gone off about ten times in the last hour. Flicked back on almost straight away. Seems ok now.
« Reply #26 on: April 28, 2013, 09:23:11 PM »
Just checked out the website and it looks like they only do spares.
« Reply #27 on: April 28, 2013, 11:51:29 PM »
they do sales as well. ask martyn. think there are so many dodgy ebay sellers they don't bother advertising any more.
« Reply #28 on: December 04, 2013, 01:54:46 PM »
Just an update to this thread.
Investigated the strange grinding noise - turned out to be a well knackered main bearing. Strange thing is - it seems Lizzie is a bit of a weird one. The main bearing on the side that drove the compressor was a split type. The chap I spoke to at stationary engine parts had never come across one like this.
Anyhow, managed to modify a standard bearing to fit into the split casing.
Then she got cooked. My fault - the cooling system was airlocked and I didnt spot it in time. Exhaust valve seat was in pretty poor state after that - zero compression. A quick regrind and she's running again, but I'll need to fit a new seat next time the head is off.
As of this moment though, she is powering the plant cooking up a batch, my dishwasher, laptop, TV and lights.
You could say that this message has been posted by Lister power.
« Reply #29 on: December 04, 2013, 03:14:07 PM »
Very good. Sounds as though its when and not if with listers self immolating. At least they are easy enough to repair. Always amazes me how these old engines always seem to have a thoroughly knackered big end , not just a slightly worn one. Surprising how the keep going so long.
Ae you still running part WMO?
Oh, it's not the big end...........
