Author Topic: Mid batch - Glyc not separating after glyc wash.  (Read 6325 times)
Re: Mid batch - Glyc not separating after glyc wash.
« Reply #15 on: May 08, 2013, 05:20:45 PM »
To update this.
I had 100% reaction & no unconverted oil after doing the first stage using 17% meths & 8 grms of KOH.
Anybody have any idea why that should be the case?
« Reply #16 on: May 08, 2013, 07:10:09 PM »
To update this.
Low titrating dry oil.
« Reply #17 on: May 08, 2013, 07:20:06 PM »
The initial problem of the glyc not dropping out was diagnosed as wet oil. Are you saying the glyc wash & leaving it for a few days made it dry enough to get away with a one stage treatment?
If that's the case I might do it every time.
« Reply #18 on: May 08, 2013, 07:35:25 PM »
I'm pleased that you got this sorted niesel but as a caviat it should be mentioned that leaving glyc wash for 4 days inside a reactor could result is a mother of a problem if you use NaOH. This is more for newbies reading this than the more experienced brewers.
I have to say I've never experinced a sitution where the glyc fails to drop and I use the glyc wash as my only drying method....but I do know my oil.
As an aside it may also be prudent to take a sample from the reactor before turning off the pump. You can then see what's going on inside the processor from the outside ;)
« Reply #19 on: May 08, 2013, 08:42:58 PM »
Neisel did the glyc drop out on it's own or did you do something?
I haven't done a glycwash for a long time but I had the glyc/wvo mix go really thick and gloopy like marg/butter and had to add more wvo to get it to separate again
« Reply #20 on: May 08, 2013, 10:33:13 PM »
The glyc dropped out on it's own, I did nothing extra except give it time to do whatever it was going to do.
« Reply #21 on: May 09, 2013, 07:01:22 PM »
Was this with the oil you got from me ?
