Author Topic: Reclaimed meth.  (Read 5118 times)
Re: Reclaimed meth.
« Reply #15 on: April 03, 2013, 09:55:59 PM »
This is better than TV  :)
Re: Reclaimed meth.
« Reply #16 on: April 03, 2013, 10:02:14 PM »
Then perhaps you need to write a little clearer.  :o
Perhaps you should go to specsavers, it'd be clearer then, he of restricted vision. ha ha ha la la la.
Re: Reclaimed meth.
« Reply #17 on: April 03, 2013, 10:02:53 PM »
...anything is better than TV!
Re: Reclaimed meth.
« Reply #18 on: April 03, 2013, 10:03:46 PM »
Isn't it, he's an argumentative old sod in'e.
Offline Oilybloke
Re: Reclaimed meth.
« Reply #19 on: April 04, 2013, 06:51:16 AM »
I knew what you meant, Jim.
Offline mon
Re: Reclaimed meth.
« Reply #20 on: April 04, 2013, 01:05:31 PM »
My hydrometer arrived today (would you believe that no-one stocks them over here?!) and warmed the meth to 20c. Plopped the hydrometer into the sample, and it just sank straight to the bottom! It's a brewer's/winemaker's one, have I fkd up?
So I decided to weigh a sample. Given that a litre should weigh 794g, my 100ml sample weighed 84g but over a 15 minute period went down to 80g. I did this twice, with the same result.
Answers on a postcard please......
The hydrometer you have will only measure upto 100% ethanol.
Ethanol = 789 g at 20°C
Methanol = 794g at 20°C
so your sample weighs less than this, http://www.biopowered.co.uk/wiki/Testing_methanol_purity
Worst case
794g at 20 degrees is atleast 98.5% pure.
Re: Reclaimed meth.
« Reply #21 on: April 04, 2013, 02:28:53 PM »
Sounds like the battery in your scales needs replacing if it changes over time.
The hydrometer sinking suggests it's pure enough to me.  Mine is an alcohol hydrometer and if it sinks, I know it's good to re-use.
I did some tests with fresh Meth (not reclaimed) and it sank in that, but if I added 1ml of water to the 100ml sample then the hydrometer would rise.
