Author Topic: wanted : new venturi - are there 'off the shelf' options?  (Read 20684 times)
Re: wanted : new venturi - are there 'off the shelf' options?
« Reply #30 on: March 20, 2013, 08:31:38 PM »
Ah does that mean ours are not supa dupa models ?
Nah sorry, they're merely master pieces of the venturi art, supa dupa and supa dupa dupa versions are for very specific plants.......................................Mine.
« Reply #31 on: March 20, 2013, 08:43:48 PM »
how did it break? did the bio eat through
Went sticky then cracked
They ALL crack in our aplication.
BTW there's absolutely no need for Bullsh!t Amplification in my case, it can be seen from space.
Offline Huntman40
« Reply #32 on: March 20, 2013, 10:17:59 PM »
Would you happen to know what material it was made of?
« Reply #33 on: March 20, 2013, 10:20:10 PM »
Sorry I can't remember but the make was something like mazzuri?
Offline uberveg
« Reply #34 on: March 20, 2013, 10:28:33 PM »
Hi, I've just imported a Venturi sample like the one on ebay. It's made from pvdf, rated to above 150c and claimed to be bio compatible.
I'm going to supply this as a new product line, if anyone wants to try the sample for a reduced price then give me a shout. Should also have some larger eductors for 100+ litre pumps within a few weeks.
Cheers,
James
« Reply #35 on: March 21, 2013, 06:27:04 AM »
welcome uberveg
Offline uberveg
« Reply #36 on: March 21, 2013, 01:47:09 PM »
Hi, thanks for the welcome. Very relaxing forum
« Reply #37 on: March 21, 2013, 03:05:18 PM »
We talk in hushed whispers on here. Even Jim's trumpet is muted.
Welcome btw. :)
« Reply #38 on: March 21, 2013, 04:27:18 PM »
Welcome btw. :)
I have sufficient knowledge and experience of Plastic Venturis not to go down that road, I've said on many occasions what happens to them, no need for the trumpet.
« Reply #39 on: March 21, 2013, 04:36:12 PM »
Welcome btw. :)
Edit: One for Keith  ;)
« Last Edit: March 21, 2013, 04:39:17 PM by Tony »
Offline uberveg
« Reply #40 on: March 21, 2013, 05:22:17 PM »
Welcome btw. :)
James - You probably have experience of ventruis made from ABS - these melt in Bio and are manufactured by Mazzei. The ones I have sourced are PVDF (polyvinylidene flouride) and are completely impervious to Biodiesel and methoxide, boasting high tensile strength and rated to above 150 centrigrade.
Check the vacuum experiment I did in the lab http://youtu.be/vE-eH8mbwKA
Not bad, eh?
James
Offline Huntman40
« Reply #41 on: March 21, 2013, 05:43:28 PM »
But, you were wrong about the plastic eductors. They are made of polypropylene and biodiesel seems to have no ill effect whatsoever. Plastics are moving on!
i like the video  :)
What flow and pressure do you think is available from the mains?
we use PVDF tubing at work for fuel tank harnesses,  MOD stuff
« Last Edit: March 21, 2013, 05:49:07 PM by Huntman40 »
« Reply #42 on: March 21, 2013, 07:51:48 PM »
Is that right, How many broken, damaged, deformed and disintegrated PLASTIC eductors have you replaced?
One problem with the ones for sale atm is they don't comply with the dimensions that R&D both here and in the USA developed for WVO conversion, NOT water.
« Reply #43 on: March 21, 2013, 07:59:02 PM »
Not bad, eh?
James
What's 10 ATM?
BTW using cold mains flow means NOTHING, there's absolutely no comparison with wvo at 40 - 50°C and a 40ltr min pump.
What's the mix ratio, liters of motive flow to liters of methoxide.
What pump flow rate is the venturi tuned to and don't just refer to the manufacturer's chart 'cause it won't be right in our application.
« Last Edit: March 21, 2013, 08:03:48 PM by jamesrl »
Offline uberveg
« Reply #44 on: March 21, 2013, 08:06:33 PM »
Wow. Lets have a cooling off period.  ???
