Author Topic: whats the best bio processor setup for a newbie?????  (Read 5073 times)
Offline Brian_B
« on: March 10, 2013, 03:22:53 PM »
As above guys, ive been searching the forum but would like to be pointed in the right direction on a setup that
Would be ideal for myself who is new to this BD processing. And I suppose theres no better people to ask then you guys who are homebrewing already.  ;)
Re: whats the best bio processor setup for a newbie?????
« Reply #1 on: March 10, 2013, 03:47:59 PM »
In just about every respect, the best way is to build one.
It's very much cheaper than buying and you get to learn about, and feel confident with, your own machine.
You only need basic plumbing and electrical skills and a good read of the wiki.
Failing that there are members on here who will build a SAFE processor to suit your requirements and train you how to use it ... just DON'T buy anything off eBay and be very careful with processors advertised on the internet (many are dangerous).
« Reply #2 on: March 10, 2013, 03:59:18 PM »
Im helping a friend build one at the moment.
(the plan was that i watched and answered questions, but, alas...)
If you can locate somone close to you who has built a unit, im sure they would help.
« Reply #3 on: March 10, 2013, 04:54:03 PM »
Fact is you can make bio with a drum, a pump, some pipes and not much else.  Maybe an air pump to bubble the Meth out if you're not water washing.
It's the Meth recovery and everything else that adds to a plant's complexity - it really depends what you want to do (water wash, or demeth and settle)?
« Reply #4 on: March 10, 2013, 05:14:37 PM »
Offline Brian_B
« Reply #5 on: March 10, 2013, 05:46:38 PM »
Thanks for your replys guys,
Im thinking allong the lines of waterwashing rather than the de-mething and settling route, the demeth seems a bit complex at this stage for me  :-\.
So if I wanted to built a processor that could do the job from start to finish using the water wash method
What would be the basics to get me going???
I understand im probably asking questions that have been answered on the wiki but id rather pick
Your brains breifly and get a idea of componants and cost.
Thanks again guys.  ;D
« Reply #6 on: March 10, 2013, 05:51:03 PM »
Get an oil collection before you start buying/making kit.
Can you fabricate? You going to need a coned drum to start with, then build it up from there.
« Reply #7 on: March 10, 2013, 06:11:58 PM »
A blue, sorry, Black one, it'll do everything you could ever want to do when making bio.
« Reply #8 on: March 10, 2013, 06:55:32 PM »
Start with a GL type unit, these are the safest home built reactor, they can be upgraded if and when you feel the need.
The easyest way is to start with a central heating water cylinder (immersion tank), but these are quite small if you do a reasonable amount of miles,
so you may want to go for a 205L drum with a cone on the bottom, jamesrl can make you anything from this to a full setup.
But as said above, get an oil collection round sorted first as this can be the hardest part.
Offline Brian_B
« Reply #9 on: March 10, 2013, 07:10:26 PM »
Im a panel beater by proffession which as some might know involves allot of fabricating and welding of new panels, Ive already started whith the oil collection side of things, so I just need to crack on with the fabricating of the processor.
Offline Brian_B
« Reply #10 on: March 10, 2013, 07:31:04 PM »
Thanks once again for the quick replys guy's ;) ill crack on with the 205l drum idea because of the miles I do
Commuting to and from work.
it must be quite satisfying after youve got your processor up and running and
Pumping out your first batch............ althought something tells me thats when the fun and
Problem solving starts aswell. Ha  :-\
« Reply #11 on: March 10, 2013, 07:41:23 PM »
A cone bottomed 205 will give you a batch size of 180L (of oil) and takes no longer to compleat a batch than a smaller unit,
so it's the way to go for you.
It's not just the first tank of fuel that gives you that nice warm feeling, it stays with you for many years.
« Reply #12 on: March 10, 2013, 07:47:19 PM »
you can bash a bottom out of an oil drum just enough to drain all into the center...
http://www.graham-laming.com/bd/main.htm
http://www.graham-laming.com/bd/ecosystem/state_diagram_new.htm
« Reply #13 on: March 10, 2013, 08:05:16 PM »
Perhaps if you weren't presenting as an imprisoned Kermit and remembered your RM days, you'd recall writing this ... http://www.biopowered.co.uk/wiki/Tips_and_wrinkles_1#Strong_back_dome_puller
