Author Topic: So just how noisy are pumps supposed to be?  (Read 5953 times)
Re: So just how noisy are pumps supposed to be?
« Reply #15 on: March 10, 2013, 07:07:51 PM »
How are you securely connecting 1" pipe to your pumps?
For testing i am using pipe over 22mm coper with hose clips. I dont dare connect the eductors up
Are you referring to the pump's discharge? You can get adapters from any decent plumbing merchant 1" bsp M x 22mm fem compression or the other way around I'd imagine.  If you were thinking of wire reinforced tube, you could just use a 1" bsp M x 1" tail (brass, aluminium, steel or plastic).
