Author Topic: WVO Transfer Pump  (Read 15618 times)
Re: WVO Transfer Pump
« Reply #15 on: March 06, 2013, 06:14:14 AM »
We use this style of pump at work for pumping thick gloopy oils contaminated with particles:
http://en.wikipedia.org/wiki/Diaphragm_pump
http://www.netpumps.com/air-operated-pumps.html
http://www.fluidpumps.co.uk/wildenpumps.php?gclid=CLPt05a457UCFchY3godqXoAyA
Will pump nearly anything! Although they'll use a huge amount of air.
« Reply #16 on: March 06, 2013, 06:35:20 AM »
HOW MUCH!!!???
Looking at the rotors, it looks very much to me like the same principle as a hydraulic pump off a digger. If it is, it would rip your fingers off, spit them out without changing its speed, and then start on the rest of your hand.
So long as it doesn't hit metal.
Like the sound of that!
reminds me of the guy (forget who) who put a car windscreen motor (its slow geared) on a hand rotary pump. cheap cheerful powerful and 12 volt. = nice, that can pump veg with inch bore i believe...
could even use this off your car batt on waste oil collections  ;D sort the wireing and you could get 2 speeds and intermitant, yes nice bit of kit.
« Last Edit: March 06, 2013, 06:46:27 AM by Ping Pong from pong ping »
« Reply #17 on: March 06, 2013, 04:24:08 PM »
I actually have one of those in my garage.  Just need a 12v windscreen motor :-)
« Reply #18 on: March 06, 2013, 05:56:18 PM »
rotary hand pump do pump well and they run backwards to, i used it to suck out a tank, i use mine alot...
even to back pump oil out of a barrel bed sheet back into container to change sheet filter
« Reply #19 on: March 06, 2013, 06:33:16 PM »
I use one of these and an inverter when needed
« Reply #20 on: March 06, 2013, 07:57:07 PM »
still got mine never used it, i may sell it if anyones interested?
Offline jkis
« Reply #21 on: February 02, 2014, 08:13:53 PM »
i use a onga trash pump, 720 ltrs per min, run it just over idle and from an ibc on the ground to one on the truck 2 minutes max.
i did purchase a 15 gpm gear pump http://www.wvodesigns.com/shop/clearance/15gpm-goldstream-waste-oil-monster-pump-head-only.html  the freight is the killer here,  will put it on a 240 volt motor but would like to try a electric scooter motor on it 1st. there cheap and can run them on 12v or 24v if you want it to go faster, i put one on a small hand chaff cutter @ 12v it works okay more torgue needed,
after purchasing these items i found "chev small block oil pumps" worth a google  also on utube.
cheers stuart
just keep it simple
