Author Topic: Soap test results. Whats ok?  (Read 3167 times)
Offline Soft top
« on: February 25, 2013, 06:21:04 PM »
I received my soap test kit today.  Thanks Nige.
I did a test on some bio that I made about a month ago and the result was 192 ppm.
I know that the lower the ppm the less soap, but I was wondering what is the highest ppm that is ok to use in the car without causing damage? Anyone know?
Re: Soap test results. Whats ok?
« Reply #1 on: February 25, 2013, 06:26:41 PM »
Depends on your car!  And the soap, if jiggled about enough in the tank, can form larger lumps which block filters.
When I was running soapy (250ppm+) I had hard white deposits form on the glow plugs in the pattern of the injector spray, can't see that being too good for the engine either.
« Reply #2 on: February 25, 2013, 06:27:41 PM »
Reading The Test: - If your fuel tests within the ASTM limits, well done. Your methods are first rate.
100-200 PPM, it shouldn't pose any real problems associated with fuel filter clogging.
200-300 PPM, you should be looking at ways of improving your process.
300-400 PPM, the likelihood of filter clogging may increase and soap content is getting high.
400+ PPM, do not use this fuel in a modern CRD (Common Rail Diesel) engine. Your soap and Methanol removal methods should be looked at again.
500+ PPM, there's a good chance you'll see cloudy water in a 50/50 shake test.
« Reply #3 on: February 25, 2013, 06:39:50 PM »
Soft top....sorry mate. I've not sent the instructions over. The details that Keith has put up is on the sheets. You should have the attachments in your email in a couple of minutes.
The bit that Keith has missed off are the acceptable limits....here they are:
Acceptable ASTM Limits For Soap
- NaOH Reacted Biodiesel - No more than 41 PPM (0.041%)
- KOH Reacted Biodiesel - No more than 66 PPM (0.066%)
Nige
« Last Edit: February 25, 2013, 07:38:19 PM by nigelb »
Offline Soft top
« Reply #4 on: February 25, 2013, 06:55:36 PM »
Got it now. Thanks. I found out what to do by watching your You Tube tutorial.
Im going to do another batch tomorrow so will be playing with the kit before and after water washing.
« Reply #5 on: February 25, 2013, 07:28:36 PM »
I wonder if you'll get similar results to those I got at the weekend.
Offline Soft top
« Reply #6 on: February 26, 2013, 01:38:11 PM »
Oooops I got it wrong.
When I did I the test I had no instructions and I thought the small divisions on the small needle were .1ml not .01
I have just done a new test and this time I put in a bit more acid to be absolutely sure of the colour change.
I put in a total of .08ml.     So .08 x 320 = 25.6 ppm  I think I have done it right this time but did not expect the result to be that low.
