21
Chatter / Re: VOD gone for good?
« Last post by neisel on April 05, 2024, 04:51:25 PM »Judging by the level of activity on here I'd say biopowered isn't far behind VOD.
Really depends where the oil is going - could be a turbo seal, worn valve stems, gasket, piston rings... Does it smoke badly if left at idle for a bit and then revved? This might indicate a turbo seal.
A good steaming or water injection wouldn't do any harm if the rings are getting gummed, that's for sure.
What engine is in it? How smokey is it on start up?
If you take the oil filler cap off when it's running is it blowing out a lot like the crankcase pressure is higher than it would normally be?
