General => Wiki and forum discussion => Topic started by: Chug on June 25, 2020, 08:09:45 PM
Anybody else got nothing in their inbox or sent folders, all mine are gone and I tried to PM Dave and nothing?
I've been sending and receiving PMs OK - but that doesn't mean they work for everyone. I'll PM you Chug and see if you get it.
And I'll run some of the database cleanup tasks. Edit: Completed.
The other thing to check is going into personal messages, then on the left column at the bottom is "Change Settings"
It may be the "Receive personal messages from:" is set to Administrators only?
I've sent you a pm Chug to see if you get it. It does appear on my sent items list.
Thanks Chug, all the info has come through ok, thanks.
I can't see my sent PMs.
Only the recipient's replies.
Go to the menu bar above, select Profile -> Account settings
Then on the left select Personal messaging. There should be a tick box, "Save a copy of each personal message in my sent items by default."
